Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 29th October 2012, 07:17 PM   #18671
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
That sounds rather strange, as this cap provides power to the servo and digital section. I can't imagine that treble becomes totally rolled of by this one cap. What you describe has more to do with something being wrong in the analog section, did you change something there as well?
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 29th October 2012, 07:26 PM   #18672
badrisuper is offline badrisuper  India
Ray
This is the only change I tried, no changes in analog section. Earlier with Nichicon 4700uf/35v it sounds good, but after change i feel like vocal is to my face. But improvement in bass. After I change I was listening to it for 7hrs. I felt tired. To fit the capacitor through the hole, i extended a thin lead to insert into the hole. Is it ok?
Badri
Old 29th October 2012, 07:46 PM   #18673
6h5c's Avatar
I would be tired too, after 7 hours ;-)
Improved bass sounds logical with a larger cap, and the in-your-face vocals could indicate improved placement and soundstage. The fact that you don't like this (yet) may be caused by the player not being fully modified.
First, I would give it some more time, don't judge too quickly. If you still think the sound is not o.k. after a few days, or maybe a week, there's only one thing to do if nothing else of the electronics was changed: change it back to the Nichicon and see (listen) if the treble is back and decide if you like it better this way.
A bigger cap is not always better, you know. I'm not too fond of replacing a cap by an extremely large one (5x or 10x the value) personally, but the original is 4700uF, so 10.000 should be o.k.
Ray
Old 29th October 2012, 08:09 PM   #18674
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz CD63 & CD67 mods list
I have a 22,000uF of the same cap there and I personally like it a lot. The AG are supposedly similar in construction to Black Gates, which are said to emphasize bass somewhat, and I think you may be correct that the very high treble may be rolled off a tiny bit, but the balance sounds more natural to me and more comparable with vinyl. My speakers are two way monitors and very revealing of harsh treble, so I personally like the effects of the larger caps. I seem to recall that bypassing them with small value X7R or film caps 'undid' some of the effect, which I perceived as reducing bass and re-introducing a harsh top end, but you might like it. However, as Ray says, wait for a while - at least a couple of days.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 29th October 2012, 08:26 PM   #18675
Bigvoice is offline Bigvoice  United Kingdom
When I first changed the stock Tx by 3 Txs and changed the 4 smoothing caps to 22000uF on both the servo and the analogue rails I also had the same feeling as yours that the bass seemed to be too much. By that time I had not changed the clock and independent power supplies to the DAC,decoder and servo etc. I think it was because the bass became more tight and extended and therefore we just felt the high frequencies was not right - this is just relative because there was more LF going into your ear drums. By the time I changed the two clocks, the independent power supplies and using burson opamps the music became more balanced with clarity and excellent soundstaging. Therefore don't jump to a conclusion too soon until you have finished with all the mods.
Old 29th October 2012, 09:47 PM   #18676
higlander is offline higlander  United Kingdom
Well, I tend to agree with Bigvoice. I have just changed the original on the board transformer to 3 standalone TXs. I have also changed the smoothing capacitors to 22000uF. On first hearing I also had a strange feeling that the bass was too much. It seemed the sound was not right. I believe my mind had got accustomed to the previous sound quality. When there was a big change in SQ my brain cell just could not cope with it. When I asked my wife who seldom listened to my CD63 for her opinion she said the music was alright and said there was nothing unusual apart from the very tight and extended bass which was not present before the modding.
I have not yet changed the the 2 clocks and independent power supplies to the DAC and decoder etc. I think when I have completed the mod my brain cell will need sometime to get use to the new SQ.
Old 30th October 2012, 12:29 PM   #18677
Its not 7 continuous hours.
Old 30th October 2012, 12:32 PM   #18678
Thanks Ben, BigVoice, Highlander. I will run it for few days and then see the difference.
Old 2nd November 2012, 07:02 PM   #18679
I noticed that my two + and - 15V low noise regulators are very hot even though I put in a heat sink on each of them. I think they are at least 80 degree C !! I believe it is due to the high voltage drop from 30V to the regulated voltage of 15V and the excess power is dissipated as HEAT. Luckily there seem to be no problem on long time continuous operation, i.e more than 4-5 continuous running. I wonder if anyone has the same heat issue on their regulators for the analogue section ??
Old 2nd November 2012, 08:33 PM   #18680
UV101 is offline UV101  England
UV101's Avatar
What's the input voltage 30v? That's far too high. You only need a 15v transformer. It will output about 22v which will be more than enough.
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Marantz CD63 & CD67 mods listHide this!Advertise here!
