Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th October 2012, 01:41 PM   #18661
qusp is online now qusp  Australia
is choosing a less facetious title...
qusp's Avatar
this would be very prone to noise pickup
Old 26th October 2012, 02:18 PM   #18662
Thanks and that was what I had in mind when I had this idea.
BUT I need to know from someone who has actually done this before and I want to to hear from them the actual result, whether good or bad.
Old 27th October 2012, 08:35 AM   #18663
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
You can clock two chips with the Flea, one on each output. If you use tightly twisted wire or thin coax, you will have no noise issues.
Just make sure you disable the PCB track that runs on the board from the DAC to the decoder, a lot of people forget that. Remove RD14 and a few wire-jumpers. If you leave the unused trace connected to the clock signal at one side, then you'll have a noise-antenna :-)
If you are using a CD57/67, make sure to connect the clock to the other side of R104, which would be pin 21 (CRIN) of the SAA7372. Marantz used pin 22 (CROUT)
The schematic is correct, but look at the board traces...
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 27th October 2012, 05:43 PM   #18664
Originally Posted by 6h5c View Post
You can clock two chips with the Flea, one on each output.I
Ray
Thanks Ray. Great !! I don't realize that your Flea got two outputs, one for DAC and the other for Decoder until you mentioned it and then I looked it up in the manual.
BTW are the two O/Ps just connected together without any buffered separation ?
Old 27th October 2012, 06:02 PM   #18665
Today I finished connecting the three Tx onto my CD63 and they work like a charm. I have posted up a few photos to show what I have done so far.
You can see my 4X22000uF smoothing capacitors and their leads are surrounded by copper foils which I have earthed to get rid of interference. The case is also heavily damped. The analogue rails are fitted with Korean built +15V and -15V low noise voltage regulators. Two Burson discrete opamps are fitted. You can also see that most of the capacitors are changed to Rubycon ZLG, Sanyo SEPC and WIMA caps. The sound quality is really nice and the bass is so tight and deep.
When Ray's two low jitter clocks arrive I will feed independent 16.xx and 8.xxMhz signals to the DAC and the Decoder as well as the servo. Afterwards I will build five low noise voltage regulators using LT-1763-5 to provide independent power supply to the servo, DAC and Decoder etc. Then I think the mod is considered complete by that time.
Old 27th October 2012, 08:15 PM   #18666
I forgot to mention that all rectifier diodes were changed to Vishay 1n5062.
Old 27th October 2012, 11:04 PM   #18667
bikeral10's Avatar
Default re cap
The leads from your caps are way too long.Copper aint gonna help.??
alan
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 28th October 2012, 07:18 AM   #18668
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Send a message via Skype™ to Ben Hanke
Hey guys, just an update on the individual DAC analogue PSU. Definitely subtle gains for the cost and, perhaps more importantly, space. However, after a few days with it, I feel as though it sounds tonally the same but less distorted and more capable, similar to when I doubled up the transformers in my amp (a la Brent). Definitely a worthwhile mod but only after other PSU and clock mods, I'd say.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 28th October 2012, 03:09 PM   #18669
6h5c's Avatar
The outputs are not buffered, but connected to the output of the Tentlabs XO through a 33R resistor.
Old 29th October 2012, 04:21 PM   #18670
Hi Ray,
Today I changed C813 caps to 10,000uf/25v Mundorf AG. I felt it becomes dry, treble is totally rolled of, earlier I had Nichicon FW 4700uf. Is it because of the value is too much than required? Or it need time to burn in?
Badri
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
