Marantz CD63 & CD67 mods list - Page 1864 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd October 2012, 06:22 PM   #18631
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Send a message via Skype™ to Ben Hanke
Originally Posted by Ben Hanke View Post
Mine are wired to the original IEC socket ground
RCA! The RCA socket ground! Not the IEC. OMG
@badrisuper Hint: The RCA sockets that you removed only had two connections per channel - signal and ground. You've already connected one of them.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 22nd October 2012, 10:35 PM   #18632
bikeral10's Avatar
Default lmfao
Originally Posted by UV101 View Post
Seriously, if you cannot identify the original output gnd connection, you really shouldn't be poking around in the player.
Why don't you have a look and the PCB and point it out to me and then I'll help!!!!
sorry couldnt help it ian im gunna fit some new opamps i got a blow lamp.
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 22nd October 2012, 10:49 PM   #18633
bikeral10's Avatar
Basic electronic theory is a help before you decide to try to modify these players we are all here to help,All of us started somewhere.
alan
Old 23rd October 2012, 06:19 AM   #18634
Thanks UV101. Please see the picture. Is it right? And I did read the DC, in right channel 14.2 and in left channel 33.8. Any suggestions.
Badri
Old 23rd October 2012, 07:34 AM   #18635
Ben Hanke's Avatar
Get a pair of good quality output caps such as Mundorf Silver/Oil 2.2uF - 4.7uF and run that signal wire through them. I got a matched pair of 3.3uF from Parts Connexion. They will block the DC for you.
Old 23rd October 2012, 08:06 AM   #18636
Thanks Ben, Can you please post pictures of yours. I have K71 Russian Cap 1.2uf value. Is that enough?
Badri
Old 23rd October 2012, 08:47 AM   #18637
Ben Hanke's Avatar
I don't have a pic of them to hand, I'm afraid. They're axial caps. The exact value required is based on the input impedance of your amp and desired low frequency rolloff. You can calculate the value you want here: Coupling Capacitor Calculator by V-Cap
My guess is your Russian caps will probably work just fine.
Old 23rd October 2012, 11:05 AM   #18638
Thanks Ben. Now the distortion gone. And I used Russian capacitor. Not bad, bass is controlled and very good but i feel like i it is little slow. I have to find a suitable cap. Any Suggestion.
Badri
Old 23rd October 2012, 11:38 AM   #18639
Ben Hanke's Avatar
Cool. Further to my previous post, here's a link to a well-regarded output cap:
Mundorf Silver/Oil Series Film Capacitors
It's probably best to get a value between 2.2uF and 4.7uF. I personally chose 3.3uF.
By the way, you might want to let the Russian caps settle in a bit before you cast definitive judgement.
In other news, I fitted the first of my dual 15v supplies this evening. It's tested and ready to hook up to the DAC analogue regs tomorrow.
Old 23rd October 2012, 12:31 PM   #18640
UV101 is offline UV101  England
UV101's Avatar
I've not seen one of these with DC on the output. Something doesn't sound right.
Cap wise, I've not used lower than 4.7uF althought I know Brent was running 2.2uF with his dos. I believe a lower value can start to effect the bass. If you are buying new caps, I'd go for 4.7uF but you may be ok with 3.3uF as Ben suggested.
When will you have a listen Ben?????
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Copyright ©1999-2017 diyAudio
