Marantz CD63 & CD67 mods list - Page 1863 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd October 2012, 08:52 AM   #18621
Originally Posted by Ben Hanke View Post
Hey guys, I've built my first separate PSU for the DAC analogue supplies using a 7VA transformer (2 secondaries @ 3.5VA), some Schottkys and some mondo smoothers. Here I go with another noob question: What do I do with the ground? Anything different? Do the ground pins become separate or the same ground as the rest of the player? I only just realized how clueless I am about this part.
I believe you are talking about the ground connection of the secondaries. I don't think you need to earth this to the PCB or the casing. when you have finished with the 5V regulator just fix the +5V to the DAC and connect the 0V to the PCB's common ground.
Old 22nd October 2012, 10:52 AM   #18622
UV101 is offline UV101  England
UV101's Avatar
I used the star point near C813 negative terminal as my gnd point for everything. Can get a bit busy tho!!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 22nd October 2012, 03:50 PM   #18623
Originally Posted by UV101 View Post
This method of direct coupling the output works here because there is 0v DC offset after the 2nd Opamp stage.
You should always check with a meter set to the mV range before you direct couple. DC into your amp could damage the amp and speakers!!!
Hi UV101,
I am hearing a kind of distortion after did the direct coupling of output. Initially I didnt hear this kind of distortion for last 2 days. Can you please tell me what will happen if DC go into amp and speaker? What should be the value if i measure DC?
Badri
Old 22nd October 2012, 04:17 PM   #18624
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Send a message via Skype™ to Ben Hanke
Thanks guys. The output of each of my 5v regulators is currently wired to both terminals of a 470uF local decoupling capacitor close to the chip. It sounds as though I can leave those connections in place until I upgrade my regs to lower noise types.
Just searched the forum for info on badrisuper's question and saw that Brent had 22mV/24mV DC offset and that went down to 2mV per channel when he moved to a star earthing scheme (for his regs?)
@badrisuper - the DC should measure as close to zero as possible. I have about 30mV offset per channel at the speaker terminals of my amplifier, which is a little on the high side. Depending on your amp/pre-amp, any DC present at the output of your player could get amplified my the same amount as the music signal. In the short term this could result in distortion and popping of the speakers, but it could also fry your voice coils and/or your amp. Did you measure it before you hooked it up?
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 22nd October 2012, 04:57 PM   #18625
Default Grounding?
I taken signal output straight away from U210 and U214. But where to ground?
Badri
Old 22nd October 2012, 05:45 PM   #18626
Ben Hanke's Avatar
Mine are wired to the original IEC socket ground, but I find I get a fuller sound if I also don't use the internal insulator rings on the RCAs and screw them nice and tight to the chassis.
Old 22nd October 2012, 06:11 PM   #18627
UV101's Avatar
Badri
Take gnd from the original point that fed the output phonos. Where are you taking gnd for now? This could be the reason for distorted output??
Old 22nd October 2012, 06:14 PM   #18628
For me at the speaker terminals I got 10mV DC on the Right speaker and 20mV on the Left speaker irrespective of volume setting of my amplifier and with or without the CD63 being turned on/off. It seems that the amplifier's input has built-in DC blocking capacitors. As to the CD63 RCA output, the measurement are both just less than 30mV DC. I did not hear any distortions at all.
Old 22nd October 2012, 06:14 PM   #18629
I didnt take the ground. Can you please tell me the position number fromt he scematic if it is there?
Badri
Old 22nd October 2012, 06:21 PM   #18630
UV101's Avatar
Seriously, if you cannot identify the original output gnd connection, you really shouldn't be poking around in the player.
Why don't you have a look and the PCB and point it out to me and then I'll help!!!!
Copyright ©1999-2017 diyAudio
