Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 16th October 2012, 07:45 AM   #18571
acoustique is offline acoustique  Romania
Originally Posted by RCruz View Post
The 63 has separated Decoder and servo chips, so you can use two clocks, one for the dac / decoder and the other for the servo.... that really makes a difference.
I agree this! thx.
Old 16th October 2012, 08:00 AM   #18572
UV101 is offline UV101  England
UV101's Avatar
Originally Posted by higlander View Post
@UV101: Having looked carefully to your photo I found that your small clock only feeds external signal to the decoder and the long black wire should be an earthing wire for the clcok. I can still see the X'tal and resistor on the servo circuit.
That is one of my regs/clocks. I had some pcb's made after I proved the design on vero. There is some logic out of shot to divide the clock by 2 for the servo section.
I didn't want the expense of 2 clocks in this player, but as stated by Ricardo, I would definitely recommend using 2 clocks once you get to a certain performance level.
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 16th October 2012, 09:53 AM   #18573
higlander is offline higlander  United Kingdom
Thanks UV101.
Actually I have purchased a low jitter clock like this and it is on its way to me by post from overseas: 1PPM 16.9344 8.4672 Mhz Low Jitter TCXO Clock Module | eBay
The clock output frequency has 2 different settings and I will use the 16.9Mhz for the decoder and the 8.46 for the servo.
Old 16th October 2012, 07:37 PM   #18574
justubes is offline justubes  Singapore
WILL is be good to have a just once seperate clock psu and to power both clocks together? I was thinking alike but mounting 2 separate clock psu will be much more work and cost.
Will the noise from both clock affect each clocks performance?
Old 16th October 2012, 10:05 PM   #18575
bikeral10 is offline bikeral10  United Kingdom
bikeral10's Avatar
Thanks UV101.
I tried one lasted 6months vintage audio lab job, i did the dac and the servo killed a couple of players till i found it was the clock?? Save up and buy a c2.And you can mount large caps on the psu ive done it with panasonic 22,000 ufs. As ian says you need to drill the pcb.
cheers alan
panasonic tsups from rs £16 aint as good as mundorfs tho
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 16th October 2012, 10:23 PM   #18576
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz CD63 & CD67 mods list
Mundorf AG snap-in caps are under 8 quid at PCX right now. Limited stocks available. These caps are perfect for the CD63 and you dont need to drill the PCB to fit - just solder about a centimeter length of wire. It helps to remove the remote bus switch that nobody ever uses.
To run 2 clocks, I found it worked well to get a small toroid with dual secondaries and build 2 separate PSUs on one compact board.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 17th October 2012, 08:05 AM   #18577
UV101's Avatar
cheers alan
Or better still get a C3 (or 2)!!!!!lol
Yep the C2 is awesome for this player. You always get what you pay for. Sure the eBay clock will be better than the std set up but they don't quote the important figures. Trust me, the is world of difference between an eBay clock and a C2.
Yep, that's the way to do it! Single transformer and 2 psu's. will add about £10 to the price with decent components!!!
Old 17th October 2012, 02:50 PM   #18578
badrisuper is offline badrisuper  India
Hi All,
I finally fixed my CD53 issue. I changed most of the caps in power supply, DAC and opamp section. Now I am planning to replace diodes. Can MUR860 be replaced in D801..804, D811..D814, D851//854, DN01/02? Or What diodes I can go for? I have access to RS components or can get it from partsconnexion, Hificollective or please suggest me any online shop to buy? I dont have access to Mouser or Digikey.
Badri
Old 17th October 2012, 04:47 PM   #18579
Ben Hanke's Avatar
I shop at all those places and they're all good. Just go with whoever can ship you the parts for less, I guess. eBay can be very cost effective for bits and bobs if you are careful who you buy from. If you go with a big store, maybe look ahead at your next mod and combine shipping with something else? RS are good for transformers.
Old 17th October 2012, 05:23 PM   #18580
Cool! Thanks. I get the fleas.
Any reference for building the psu twins: )
Marantz CD63 & CD67 mods listHide this!Advertise here!
