Marantz CD63 & CD67 mods list - Page 1851 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th October 2012, 06:05 PM   #18501
Motor is not spinning. Sometimes it rotates in either direction, sometimes it rotates very fast.
Old 5th October 2012, 06:22 PM   #18502
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Send a message via Skype™ to Ben Hanke
@Lymmlad: You're very welcome - sorry it's only partial info - I hope it helps.
@Badrisuper: Don't worry, this has happened to me a bunch of times. I bet you've just lifted a pad on one of the caps you changed. Get your DMM in continuity check mode and test the tracks across those joints, particularly around the decoder chip.
If you find a lifted pad, you can usually just scratch a bit of the solder screen away from the broken track with a sharp point, exposing the copper, and re-solder it. Check everything conducts properly before putting the board in, and try not to flex it too much.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 5th October 2012, 06:37 PM   #18503
How to do continuity check?
Old 5th October 2012, 06:46 PM   #18504
I did continuity check in most of places. I dont find continuity break. When I power on with CD inserted, motor is not spinning. You know when this happens?
Badri
Old 5th October 2012, 07:39 PM   #18505
Ben Hanke's Avatar
If you went from it spinning very fast in different directions to not at all, then my money is still on a hairline fracture somewhere. I'm only speaking from experience with my own player. Don't give up - it took me about 2 days to track my last one down. I was gearing up to find a replacement player when I finally got it. It may not be near anything you've touched either.
Old 5th October 2012, 08:01 PM   #18506
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
That's true, the board is quite fragile and it could be some nasty crack.
But you should also check the ribbon cable between the board and the mech. After many insertions the thing tends to make bad contact.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 6th October 2012, 11:51 AM   #18507
What cause "ERR 10: Radial Error"?
Badri
Old 6th October 2012, 12:09 PM   #18508
UV101 is offline UV101  England
UV101's Avatar
As you had the board out, in this case I'd say a fracture or break in the tracks somewhere.
You've not done something that most in the forum haven't done already!!!! ;-)
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 7th October 2012, 09:49 AM   #18509
I have followed the discussion in this forum and made some mods to my CD63 with success. Thansk to all the good advices given here.
Now I have ordered 3 TX as suggested by Brent, i.e. 50VA 2X12V, 15VA 2X18V and 5VA 2X12V. But I am confussed by the way how they should be connect.
I believe for the 2X12V 5VA Tx, the first secondary is connected to U312 and U311 (0 V) while the other secondat is connected to U306 and U309 (0 V) (Brent has mentioned this somewhere in the forum).
Cound Brent or someone is kind enough to show me how the outputs of the other 2 TX be connected to the PCB by indicating which Uxxx I should connect to the secondaries? I don't want to burn out the circuits.
Old 7th October 2012, 08:58 PM   #18510
Hi Brent / Ben,
Further to my previous thread I believe for the 2X12V 5VA Tx, the first secondary is connected to U312 and U311 (0 V) while the other secondary is connected to U305 and U309 (0 V).
Please correct me if I am wrong on the following connections:
U305 - 12V in from 5VA Tx
U306 - 18V in from 15VA Tx
U307 - 18V in from 15VA Tx
U308 - 12V in from 50VA Tx
U309 - Ground for the 3 Tx
U310 - 12V in from 50VA Tx
U311 - 12V in from 5VA TX
U312 - 12V in after passing through the 16.4ohm resistor.
In the secondaries it has two groups of connections like this
:----- 12V
:----- 0V
:----- 12V
:----- 0V
Shall I connect the two wires with 0V together and connect it to ground ?
Thanks a million in advance.
Copyright ©1999-2017 diyAudio
