Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 3rd September 2012, 07:53 PM   #18361
Puffin is offline Puffin  United Kingdom
Just fixed my error. Will have a listen tomorrow.
I am using a DIY "super regulator" that was the subject of a thread on Pink Fish Media. I think Martin (Acoustica) had some input into it. It uses a 7805, so no "magic smoke" hopefully.
Pic of schematic here. There was an error on one of the pics (and it may be this one? - the tranny was shown the wrong way round) (mine are the right way round )
Old 4th September 2012, 06:12 AM   #18362
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
The tranny is o.k. but the 10k resistor on the right can't be correct... It's in series with the output, so there won't be much voltage left behind it under load. I think it's not supposed to be there, I don't see it on the board in the other pictures.
It's basically a standard setup with a capacitance multiplier in front of it. Nice cheapo but effective way to reduce noise . If you use 7805 you won't have to worry about the output voltage.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 4th September 2012, 09:03 AM   #18363
badrisuper is offline badrisuper  India
Hi All,
I bought Marantz CD53 recently. It works well. I want to mod the player. First start with the basic mod. As mentioned in the thread all the 63 mods can be applied. I want to first upgrade PSU mod. I am not able to go through all the pages. Can you please help in modding PSU first? And can you please list me what are the mods can be done in CD53?
Badri
Old 4th September 2012, 09:12 AM   #18364
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by 6h5c View Post
After modding a Marantz CD63 and a CD67OSE I decided to make a list of all the various mod's I found here and elsewhere on the internet.
I'd like to donate my files to this forum, for all to enjoy!
Of course I do not pretend this list to be complete.
This is all I've done to the players so far and more good tips are welcome!
Greetings,
Ray.
Originally Posted by badrisuper View Post
Hi All,
Badri
Just go to post 1 and follow the pdf
RC
Old 4th September 2012, 09:35 AM   #18365
UV101 is offline UV101  England
UV101's Avatar
Wow! Not seen that before! In what way is it "super"? Even aside the massive resistor on the output how does throttling the input to the reg assist? I'm no expert but I'd say someone posted that circuit on April fools day!!!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 4th September 2012, 09:38 AM   #18366
6h5c's Avatar
Hi Badri,
All the mods for the 63 can be applied to the 53. Look on my website for more recent modslist. The one for the 63-KI is the most fancy one.
You should start by upgrading the capacitors and rectifier diodes in the power supply. Then upgrade the capacitors around the IC's. Remove the muting transistors and the output capacitors. Add a decent clock. For the 53, add some low-drop 8V regulators for the +/- 10V driver voltage and increase the capacitors for those voltages, or add an extra transformer for the driver section. Upgrade the filter components around the opamps and the opamps too. Or go fancy right away and add a DOS output stage that replaces all the opamp circuitry.
It will already be a completely different player after this, in a positive sense
Ray
Old 4th September 2012, 09:47 AM   #18367
6h5c's Avatar
Hi Ian,
The 10k output R is a typo I guess
It's a very simple but effective circuit, the transistor acts as a voltage follower AKA emitter follower. Any voltage on the base is present at the emitter, minus the Ube voltage drop, which is about 0.65V. The voltage on the base is created by the low-pass filter 10k/3u3. This is a 5Hz filter, so the DC voltage there is quite quiet . The transistor buffers this voltage and provides the current needed by the circuit behind it, which flows in from the collector.
There's a nice article on Acoustica.org.uk, see part two of 'Using three-pin regulators'. The Flea also uses this as a front-end
Ray
Old 4th September 2012, 10:26 AM   #18368
UV101's Avatar
Thanks Ray, I've learned something today!!!! I'll have a read over on martins page a bit later
Old 4th September 2012, 01:35 PM   #18369
I should have said that the schematic I used does not have the 10k on the output, as per the pic of my reg resting on a cork.
Old 4th September 2012, 02:13 PM   #18370
6h5c's Avatar
Great! Glad to be of help
I figured that already as I didn't see the extra resistor in the cork-pic. Besides that, the regulator can't possibly work with the 10k in place
A new type of 'floating' regulator
Marantz CD63 & CD67 mods listHide this!Advertise here!
