Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 9th July 2012, 07:46 PM   #18271
NinoSimona is offline NinoSimona  Netherlands
I don't have any Black Gates STD, but I use Elna Silmic II in my DOS. I found that bypassing them with some 220n Wima MKS takes away the harshness and improved sound in general IMO.
Old 9th July 2012, 10:14 PM   #18272
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz CD63 & CD67 mods list
I have some spare 220n MKS. I might give that a try some time - thanks.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 10th July 2012, 06:43 AM   #18273
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Originally Posted by Ben Hanke View Post
Plugged my DOS in last night. LEDs came on but no sound. Ho hum.
Hi Ben,
Any sound yet? I can post the schematic with voltages, so you can check the circuit if you like.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 10th July 2012, 07:23 AM   #18274
Ben Hanke's Avatar
That would be awesome, Ray. Honestly I'm not 100% sure I connected to the DAC correctly. I wired each +/- PWM out pin to the input on the side of the PCB with the corresponding regulator and the grounds to the analogue ground pins between them.
Old 10th July 2012, 09:11 AM   #18275
6h5c's Avatar
+In and -In of each channel go to RO/LO and RON/LON of the DAC. So +In to pin 25, -In to pin 23 and GND to pin 24 (U197) for the right channel, +In to pin 18, -In to pin 20 and GND to pin 19 (U198) for the left channel. Remove RD21 to RD24 by the way. Be careful with the traces on the player's board, they are very thin.
Then all you need is +/-15V supply voltage at the other side of the DOS board and you should be able to enjoy heavenly music at the output-pin :-)
Ray
Old 10th July 2012, 09:33 AM   #18276
Ben Hanke's Avatar
Thanks Ray, that sounds like what I did except I just removed the op-amps for testing and not any of the resistors. Would they have stopped it from working?
Old 10th July 2012, 10:47 AM   #18277
6h5c's Avatar
No, there should be sound even if you leave the resistors in. They are 10k, so all they do is load the outputs of the DAC a bit. But it's better to remove them for a permanent install.
Here's the DOS schematic with some voltages.
Ray
Old 10th July 2012, 10:56 AM   #18278
Ben Hanke's Avatar
Brilliant, thanks Ray!
Old 10th July 2012, 11:08 AM   #18279
6h5c's Avatar
Hope it helps!
Old 11th July 2012, 08:53 PM   #18280
bikeral10 is offline bikeral10  United Kingdom
bikeral10's Avatar
Damn clock cost me 3 full rebuilds no clock in the mk3 version at the mo,Never suspected the clock sent the mech ape scrapping 2 transports. Full week no further on may be able to salvage may be 1 player.
At least i have music. alan
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Marantz CD63 & CD67 mods listHide this!Advertise here!
