Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 1st July 2012, 07:16 AM   #18251
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Hi Ben,
That's a know issue. This is to make sure all supply voltages come on at the same time at power up. Otherwise strange things can happen... If you use separate PSU's, you should be fine if they are equal in size (power) and buffer capacity, so their start-up time is equal.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 1st July 2012, 08:04 AM   #18252
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz CD63 & CD67 mods list
Hooray, with a capital Ray!
I'm on 3 separate decoder supplies with no apparent issues. I've been running that way for months. I tried combining them this afternoon as a test and it seemed to make no difference. The supplies are pretty much identical.
I've been having some start-up issues, but I think I've tracked them down to a bad servo clock connection. I have some very broken trace around that area, unfortunately. I've recently had an issue where the sled would sometimes go crazy on a cold start but would be OK if I turned off and on again. I got the board out today and found the servo clock was loose and it seems OK now.
I'm thinking about doing a couple more Fleas for at least DAC analogue supplies.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 1st July 2012, 08:14 AM   #18253
poynton is online now poynton  United Kingdom
poynton's Avatar
Originally Posted by bikeral10 View Post
my next question would it be worth my while to transplant a 63se tx to a 63 std save me a lot of swapping.
alan
Short answer is No.
If you want an improvement, use a KI transformer (or multiple transformers)
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 1st July 2012, 08:25 AM   #18254
Ben Hanke's Avatar
I did a bit of experimenting recently with my transformers. I went back to the stock KI Tx as a test and was blown away by how much of a step backwards it was. It was unlistenable; just too harsh on the treble. I'd say definitely get yourself a big 50+ VA servo PSU. I currently have the original KI transformer just for my display, so there's loads of room.
Old 1st July 2012, 09:09 AM   #18255
6h5c's Avatar
Ok, your decoder supplies are fine then. The servo indeed benefits from a large, regulated PSU. You can still use the original transformer to power the peripheral stuff, like the display and microcontroller.
Ray
Old 1st July 2012, 03:44 PM   #18256
lymmlad is offline lymmlad  England
Ben, do you mount the bigger transformer within the case or externally and if externally how do you do this? Thanks in advance.
Old 1st July 2012, 04:02 PM   #18257
Ben Hanke's Avatar
Default Servo PSU
There's definitely some room for individual experimentation with regard to PSU placement, but I find that a 50VA 12V Nuvotem fits in quite nicely behind the CD tray. Wire the secondaries to U308 & U310 and centre tap / both grounds to U309. Tape the original servo secondaries up securely with electrical tape to make sure they don't touch anything or each other.
See this post by Ian for suggestions on how to go further.
Brent also has a good summary of upgrading the servo section on his site here
Ben
Last edited by Ben Hanke; 1st July 2012 at 04:20 PM. Reason: Added link to Brent's upgrade guide
Old 2nd July 2012, 08:27 AM   #18258
Chivvyp is offline Chivvyp  United Kingdom
I just discovered this note in the SAA7345GP (decoder chip) datasheet:
1. All supply pins must be connected to the same external power supply.
Whoops...!
I always read that as they should all come via one mains lead.
Old 2nd July 2012, 06:25 PM   #18259
UV101 is offline UV101  England
UV101's Avatar
Sounds spot on to me!!!!!!
A bit off topic, but I treated myself!!!!
Its got 680va transformer, 160,000uF smoothers in the power amp psu and 80,000uF in the preamp. Runs 80+80W full class A fully balanced if you have a balanced source, has a stepped attenuator volume control that runs via 24 relays switching the resistors in and out! I weighs just under 30kgs and best of all its got massive proper analogue VU meters that are lit blue!!!
How does it sound?........er like nothing I've heard previously! I'm actually quite speechless which for me is quite unusual!!!!
Couldnt resist having a look!!!!!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 2nd July 2012, 07:14 PM   #18260
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
Lovely Mushroom
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Marantz CD63 & CD67 mods listHide this!Advertise here!
