Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 24th June 2012, 10:02 PM   #18241
bikeral10 is offline bikeral10  United Kingdom
bikeral10's Avatar
Default cd63
Back too it ,clocked the dac and servo on mk2 atempt all good so far.
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 24th June 2012, 10:14 PM   #18242
UV101 is offline UV101  England
UV101's Avatar
what clock are you using Al?
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 24th June 2012, 10:16 PM   #18243
bikeral10's Avatar
Talking cap choice
Originally Posted by UV101 View Post
Not tried those fr's so I've not idea how they sound. Specs look interesting. I'd be using tsup 6800uF smoothers on the audio rails and 22,000uF on the +/-10v rails (v important) also no panasonics after the regs. You've taken warm sounding audio focussed silmics out of the post reg position and replaced with these fr's which are an unknown. The whole thing about the KI is its toroid transformer and then cap choice over the std model.
Rule of thumb, in the absence of Mundorf and black gate, use large Panasonic tsup smoothers that you need to mount on short leads to fit before the regs (and on the -10v). Use rubycon 470uf post reg +/-12v and a zl after the 5v reg. use 470uF zlg for all analogue local decoupling and use solid polymer for digital decoupling.
Caps influence the psu rails and the psu rails are what you hear!!! Crap rails, crap sound!!
On a different subject, I noticed Brent has changed the order on his mod packages and replaces the transformer in the level 1 now. I've got a couple of 63se's std. I'm going to change just the transformers in 1 and compare
Nice one ian oscons in short supply ive used nichicon ls great value from rs @ the mo like the tsups too.
Old 24th June 2012, 10:29 PM   #18244
UV101's Avatar
Nah!!! Lee's got loads!!!!
Old 25th June 2012, 07:10 AM   #18245
bikeral10's Avatar
Default clock
Only a cheapie ian,
£25 from taiwan does the job pretty stable too.
alan
Old 26th June 2012, 09:49 PM   #18246
bikeral10's Avatar
C815 will 4700uf zlh 10v be okay saves me ordering again from rs.be nice guys im fragile after my last atempt.
alan
Old 26th June 2012, 09:54 PM   #18247
UV101's Avatar
Hi Alan, that's pretty much exactly what I'd use there...in fact if I was ordering right now, I'd probably choose that exact cap!!!!
Rail is 5v so voltage ok, values good and I like ZLH's!!!!!!!!
Old 26th June 2012, 11:18 PM   #18248
bikeral10's Avatar
thx ian saved me a quick fly over to bham to rs.
Old 26th June 2012, 11:25 PM   #18249
bikeral10's Avatar
my next question would it be worth my while to transplant a 63se tx to a 63 std save me a lot of swapping.
alan
Old 30th June 2012, 08:39 PM   #18250
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz CD63 & CD67 mods list
I just discovered this note in the SAA7345GP (decoder chip) datasheet:
1. All supply pins must be connected to the same external power supply.
Whoops...!
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Marantz CD63 & CD67 mods listHide this!Advertise here!
