Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th May 2012, 07:49 AM   #18181
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Send a message via Skype™ to Ben Hanke
Does anyone have any idea why my sled moves uncontrollably outwards when I switch the unit on from cold, but then works fine when switched off and on again while the capacitors still have some charge?
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 30th May 2012, 07:43 PM   #18182
Ben Hanke's Avatar
This thread is deader than my player, which incidentally is dead now.
I'm planning a postmortem on the weekend.
Old 30th May 2012, 08:34 PM   #18183
RCruz is offline RCruz  Switzerland
RCruz's Avatar
What did you do before that problem happened ?
RC
Old 30th May 2012, 08:43 PM   #18184
Ben Hanke's Avatar
Raised the driver regs to 12v.
Old 30th May 2012, 08:53 PM   #18185
RCruz's Avatar
How did you do that ?
Did you replace the stock resistors with regulators ?
Do you use the same psu to power the 12vregs and the sled mechanism ?
RC
Old 31st May 2012, 04:20 AM   #18186
Ben Hanke's Avatar
Yes, I replaced the stock resistors with 12v regs, and yes it's the same PSU. Voltage to drivers is pretty much bang on +/- 12v. I wondered if it was a timing thing - e.g. a race between my servo clock PSU and the main smoother on the positive rail.
Anyway, I've broken something while playing around with it and can no longer read discs :-(
Old 31st May 2012, 07:28 AM   #18187
bikeral10's Avatar
Dont worry ben ive done a similar thing, I smoked a driver ic good job it was only a spare and not my main player. Are driver ic s available?.
cheers alan
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 31st May 2012, 09:53 AM   #18188
RCruz's Avatar
Maybe a driver IC... quite easy to get and not so easy to replace... I placed an IC holder so I can swap IC's if they burn.
Look at the tracks between the 12regs and the first IC and also back to the PSU... these are quite thin and caused my initial issues.
RC
Old 31st May 2012, 11:21 AM   #18189
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
A big tx + psu makes a bigger improvement than regulating those driver ic's imho
Old 31st May 2012, 11:25 AM   #18190
Thomo's Avatar
It could be that the clock psu takes too long to "boot up", I had similar problems once or twice before. There is a charge-time circuit with a 4.7uF cap (I think) near the decoder. Swapping that cap for a larger one 100uF or so lengthens the time the player takes to start up and can sort the issue.
Copyright ©1999-2013 diyAudio
