Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 18th May 2012, 05:51 PM   #18171
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz CD63 & CD67 mods list
I removed the 50VA supply last night in preparation to build a standalone servo supply, reinstalling the original transformer The buzz is still there, so it must be something else. I just can't listen to it now - the bass weight has vanished and the top end is grating. I'm not sure if it's best to perservere with the servo PSU plan or just put the big torid back in! Will 50VA supply direct to driver ICs bring the bass back?!?
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 18th May 2012, 09:43 PM   #18172
NinoSimona is offline NinoSimona  Netherlands
A while ago I had also a humming torid (the original one) and that was because of a loose soldering contact on the PCB (the 10V supply, the most demanding). Maybe somewhere on the supply lines there's a bad contact? Try to move the wire a bit, to see if it disappears. I think your 9V servo chip supply must work on the standard toroid as well as the 50VA dedicated one without the buzzing.
Old 19th May 2012, 01:24 AM   #18173
Ben Hanke's Avatar
I wimped out and crammed the servo PSU back in. The sound is back again. I left the KI tx connected for the display. I think I'm still out of my depth with the driver ICs. I'm going to look at driving my DAC and decoder 5v supplies off the unused KI tx output windings instead.
TIL: Clock mods without a big servo PSU makes my ears bleed.
Old 19th May 2012, 11:34 AM   #18174
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Ben, where have you conneted the 50va tx? I thought you'd basically replaced the original tx with the 50va one for the main supply (+/-10v ish)
If that's what you've done then the driver ic's are running off that, which is what you want.
Lee.
Old 21st May 2012, 02:29 AM   #18175
Ben Hanke's Avatar
Yep, that's what I've done. I was thinking of building a separate supply for them, but I've just raised the driver regs to 12v instead. Next step will probably be to replace my 9x LM317 boards with super regs.
Old 23rd May 2012, 05:35 AM   #18176
Ben Hanke's Avatar
It's funny - since fitting the 12v regs, my sled motor goes mental when I switch on from cold, but it's fine subsequent times.
Lots of parts arrived for my DOS today. I got my FETs in matched pairs and some badass 1% silver micas
Old 23rd May 2012, 06:56 AM   #18177
bikeral10 is offline bikeral10  United Kingdom
bikeral10's Avatar
I am toying with the idea of regulating the driver ic s, Worth it or not.
cheers alan
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 23rd May 2012, 08:16 AM   #18178
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
You've not even done that Alan? That's the best mod there is on a CD63!
Old 23rd May 2012, 08:52 PM   #18179
bikeral10's Avatar
Default re regs
I know they run raw voltage but unsure to use 9v + and minus or 8v , I know i must use low drop out on pos rails am i correct. 6 in total 1pos 1 neg each ic.
thanks simon alan
Old 23rd May 2012, 09:16 PM   #18180
Ben Hanke's Avatar
I think you're safest to go with +/- 8v on the standard PSU, but if you haven't already then I'd add a 2x12VAC 50VA servo PSU and go straight to 12v regs, or you'll only end up replacing them later like me.
Marantz CD63 & CD67 mods listHide this!Advertise here!
Copyright ©1999-2017 diyAudio
