Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 30th March 2012, 03:16 PM   #18081
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
I think it was next to the DAC but I'm not sure.
Old 30th March 2012, 07:33 PM   #18082
Puffin is offline Puffin  United Kingdom
Wow 30 W per channel CD player....nice
Old 2nd April 2012, 07:15 AM   #18083
Fidelity Audio's Avatar
From memory the BK STD were fitted to the opamps and the dac so 8 in total
Brent
Old 4th April 2012, 12:18 PM   #18084
bigerik is offline bigerik  Canada
Hi guys.
I finally got a cd-63 KI and am looking to do some mods. Finally, since the KI's are pretty scarce in Canada. Is there a good précis of this thread somewhere? 18K posts are a bit overwhelming!
Thanks!
Old 4th April 2012, 12:26 PM   #18085
A lot of the information we can give you all depends on your ability to upgrade and understand the circuits. There are simple guides that cover opamp changes , capacitor swaps , clocking etc and then there are more complex upgrades that include further clocking , multiple regulator installs, transformer upgrades etc etc.
Let us know where you are heading and we can try to point you to the correct guides etc
Brent
Old 4th April 2012, 12:47 PM   #18086
Brent, I am not looking to compete with you for the worlds best cd-63!
Just looking for the best, bang for the buck upgrades. I can get some professional assistance if some of the mods are beyond my rudimentary soldering skills.
Thanks!
Old 4th April 2012, 12:57 PM   #18087
The first thing I would do is change pretty much all the capacitors on the 5V rails. All except CD15 & CD16 I would fit Oscon SEPC, if you cannot get SEPC then other oscons will do a job. If you manage to get some Blackgates that would be even better. The above mentioned capacitors I would fit 16V 470uF Rubycon ZA / ZLG.
Once these are done I remove C813 and C814. If you can get a large value capcitor connected up. We use 25V 22000uF Mundorf caps here (we do have to drill the pcb so the legs fit. You can also turn the cap upside down and hardwire to the pcb. Shorting out the two fuses helps a lot too but it is best to wait until you are satisfied with the work and it all works without popping a fuse.
The it is the output section....
Brent
Old 4th April 2012, 01:27 PM   #18088
Thanks Brett. Very enlightening!
Old 4th April 2012, 07:30 PM   #18089
I've heard in discussions before that the biggest differences are op amps and clocks. Any truth?
Old 4th April 2012, 10:26 PM   #18090
SimontY's Avatar
Yep, op-amps clocks and power supplies. That is all.
Copyright ©1999-2013 diyAudio
