Marantz CD63 & CD67 mods list - Page 1799 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th February 2012, 08:57 AM   #17981
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Send a message via Skype™ to Ben Hanke
That's interesting. Funny how the servo tx was not a big jump by itself, but I totally believe it was necessary for the sound I'm getting now. Nope, all my transformers are way over in the far top left corner. The new output tx was a fair swap for the original KI one, and that's the furthest right they go. I don't have resistors on my op-amp output - can we discount that? The increase in noise volume seems oddly exponential when I turn the dial.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 20th February 2012, 09:06 AM   #17982
Fidelity Audio's Avatar
Have you connected your chassis ground to mains earth?
Brent
Old 20th February 2012, 03:18 PM   #17983
Ben Hanke's Avatar
Nope, I don't have one. The whole system floats.
Last edited by Ben Hanke; 20th February 2012 at 03:31 PM. Reason: FACTUAL INACCURACY
Old 20th February 2012, 03:42 PM   #17984
Ben Hanke's Avatar
Haha, edited just in the nick of time for gross factual inaccuracy (just woke up). My system runs off a big 3kw mains converter that has no earth pin connected. Other sources are completely silent though. Since I added the clocks, the hum has taken on a lower frequency looping sound at about 2Hz. It kinda sounds like a car engine idling. I must stress, not audible at playback levels - only when paused and volume turned up very loud.
Old 20th February 2012, 07:53 PM   #17985
Ben Hanke's Avatar
My off-board regs use screw connectors. I'm just gonna try unplugging stuff to see if I can make it go away :-)
Old 20th February 2012, 08:16 PM   #17986
UV101 is offline UV101  England
UV101's Avatar
Do you think you have created an earth loop with one of your PSU's?
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 20th February 2012, 08:25 PM   #17987
Puffin is offline Puffin  United Kingdom
I have removed the RC switch from the rear of the player and it still won't accept a command. Do I need to connect any jumpers or anything?
Old 20th February 2012, 08:36 PM   #17988
UV101's Avatar
with the switch removed from the board, the unit will be set to use its internal IR receiver.
Have you checked the remote? If its not been suggested already, you can use a digital camera to check its operation as they will show up IR light.
Old 20th February 2012, 08:44 PM   #17989
I'll try that. Do the receiving sensors fail?
Old 20th February 2012, 08:49 PM   #17990
UV101's Avatar
Its possible but I've not heard of it. Check that you have 5v on both sides of RY11 near the ribbon to the front panel. Its the supply to the receiver.
Copyright ©1999-2017 diyAudio
