Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 17th February 2012, 09:56 AM   #17961
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
No problem Ben
Also with what Ray was saying larger uF caps usually have lower esr which causes oscillation. When it comes to standard type regs I recommend ST ones.
Brent
Old 17th February 2012, 10:33 AM   #17962
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz CD63 & CD67 mods list
I have solid tantalum on the outputs of the offboard regs, then I've wired to the chip supply pins with 470uF NX on digital and FK on analogue. The skip only happens once an hour or so and I've had the lid off a lot lately, so it might just as easily be a dry spot or dust on the runners. Guys, with servo/output PSUs and now a Flea on the DAC, this month has been huge. What next? Servo or decoder?
P.S. - It's like a Christmas tree in there now with 27 LEDs.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 17th February 2012, 01:49 PM   #17963
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Originally Posted by Ben Hanke View Post
I fitted my DAC clock. It worked first time. It sounds wonderful! The difference is immediately obvious, even from cold. Thanks Ray and Brent for making this amazing mod accessible to lazy newbies like me! :-)
Hi Ben,
That's great, i'm glad you like the result! Next thing? The DOS of course!
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 17th February 2012, 03:41 PM   #17964
Puffin is offline Puffin  United Kingdom
Originally Posted by 6h5c View Post
Have you tried flipping the remote switch at the back?
Ray
Neither position works with my RC
Can I short it out or something?
Old 17th February 2012, 05:09 PM   #17965
Ben Hanke's Avatar
You actually want the switch off, i.e. no connection. You can just remove it completely unless you want to use the (pointless?) external RC bus. You could test for continuity across the switch terminals first, as it seems odd that it would be stuck open.
Old 17th February 2012, 07:26 PM   #17966
6h5c's Avatar
Rip it out, never to be troubled by it again
Old 17th February 2012, 08:28 PM   #17967
Yess Sah!
Old 18th February 2012, 08:25 AM   #17968
Ben Hanke's Avatar
Servo clock's installed in quick succession to DAC. Player sounds so good! Huge leap in realism. No nasty surprises on my grungy 90's favourites, but on good recordings the Fleas have pushed the player into a new territory that doesn't sound like anything I've heard. I would believe it was a new format. There's new treble detail, better defining voices and cymbals, but the overall presentation is smooth and lifelike. Skipping seems gone too, oddly. Sod the display for now - screws are IN.
Old 18th February 2012, 11:31 AM   #17969
6h5c's Avatar
Amazing, isn't it? Nice work Ben.
Ray
Old 19th February 2012, 10:09 AM   #17970
Which link do I cut to take the headphone part out of circuit? I seem to remember seeing a recomendation that some additional caps are added to the rails if you do this? Where do they go and what values uf?
Rob.
Marantz CD63 & CD67 mods listHide this!Advertise here!
Copyright ©1999-2017 diyAudio
