Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th February 2012, 07:32 AM   #17951
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
Yep . It still tricks me as well sometimes...
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 16th February 2012, 07:34 AM   #17952
Fidelity Audio's Avatar
I have still to find anyone who used the remote bus system
Brent
Old 16th February 2012, 08:03 AM   #17953
Originally Posted by Audiohifi View Post
Replaced regulators with closely matched ones the voltages difference is
0.07V Will try for a while before considering a TX
Some tracks I play seem to skip or the Singer seems to hasten
Why? Laser on the last leg?
Thanks for enlightening
Hi Brent
There are two posts concerning read skipping
Please throw some light
Old 16th February 2012, 08:14 AM   #17954
UV101 is offline UV101  England
UV101's Avatar
Ben I doubt the skipping is down to that bg nx. I was using 470uf fk there without issue. Have you got another 63 available to swap transports???
Thats exactly how I started my collection lmao!!!!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
JA-88D Class A, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 16th February 2012, 08:24 AM   #17955
I found 8V regs caused minor skipping issues.
Brent
Old 16th February 2012, 01:37 PM   #17956
Brent
I am using 9V
Could it be the laser?
You know how irritating it is the to music
Old 16th February 2012, 01:46 PM   #17957
Puffin is offline Puffin  United Kingdom
Originally Posted by 6h5c View Post
Have you tried flipping the remote switch at the back?
Ray
Have I tried the switch? I have seen it and discounted it as being of no interest to me!!!. Oh bother, I have seriously missed a trick! Will try it later.
Thanks once again guys.
Rob.
Old 17th February 2012, 02:58 AM   #17958
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Send a message via Skype™ to Ben Hanke
I removed my switch to make room for big smoothers.
I just got home to find my Tentlabs oscillators waiting for me! I know what I'm going to be doing this weekend. I've got to read up on this buffered output malarkey, as I've got no idea what that means...
Hey Brent, I had the NX there before and it was skipping, so I replaced it with a 47uF FK and the skipping seemed to go away... then I put it back and got the skipping again... hence my conclusion. I'm powering the chip with a LM317 reg I built myself - perhaps it's the fault of the reg? I do have another transport I can try, and a new laser ready to fit if I can only get hold of the right kind of screwdriver.
Edit: I'm a bit hesitant to move forward with the clocks, what with the skipping, mains humming and no display for debugging... :-/
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 17th February 2012, 08:32 AM   #17959
6h5c's Avatar
Hi Ben,
Great, finally some XO's to tinker with .
The skipping can be caused by the combo cap + reg. If the impedance of the cap at the output of the regulator is too low (too low ESR), it may oscillate. Normally, there's a 4.7 ohm series resistor or inductor in the supply line, that provides damping.
So depending on the type of reg and the cap, the results may vary. Bigger caps are not always better. Read here.
Ray
Old 17th February 2012, 08:53 AM   #17960
Ben Hanke's Avatar
I fitted my DAC clock. It worked first time. It sounds wonderful! The difference is immediately obvious, even from cold. Thanks Ray and Brent for making this amazing mod accessible to lazy newbies like me! :-)
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
