Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 10th February 2012, 12:00 PM   #17921
UV101 is offline UV101  England
UV101's Avatar
Originally Posted by Fidelity Audio View Post
I use a 12V TX which equates to 16.8V pre reg leaving enough V headroom for the SPower.
Brent
And me
Service manual shows those rails as +/-10v on the std transformer!
Definately not enough for 9v regs to regulate.......I knew there was a reason I went with 8v regs not 9v when I was messing with the original set up
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 10th February 2012, 12:06 PM   #17922
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
In the KI it is nearer +/- 12V but with the large voltage drops +/- 10V is probably an RMS value
Brent
Old 10th February 2012, 12:13 PM   #17923
UV101's Avatar
Either way, you're safer with 8v regs.
Old 10th February 2012, 12:26 PM   #17924
Safer with a proper TX
Brent
Old 10th February 2012, 02:17 PM   #17925
Audiohifi is offline Audiohifi  Singapore
Originally Posted by UV101 View Post
what are the voltages pre reg?
I've previously run mine on +/-8v regs when they are running off the original supply as I think the rails may not have enough headroom for 9v. Depends on the reg drop out. Looking at the OnSemi 7809 datasheet, you need 2v drop out.
In the main player, i've got a separate TX & PSU and so use 3 pairs of 12v SPowers the same as Brent.
Over 11.5V, so is safe to regulate to 9V
Observed that Regulator output ranges from 8.8V to 9.25V after testing different brands.
Will select two closest and implement in player
Old 10th February 2012, 02:20 PM   #17926
Use ST regs and avoid On Semi if at all possible. We have had issues with many On Semi regs oscillating. They seem cheaply made too
Brent
Old 10th February 2012, 05:55 PM   #17927
UV101's Avatar
Brent
I'd go for 8v rails if I was using the original TX as I think you may well be running on the edge especially as Brent points out, you are using cheap regs.
Why not got the whole hog and get a decent sized 12v TX. Bridge and smoothers and you'll have a proper PSU.
Old 11th February 2012, 12:17 AM   #17928
NinoSimona is offline NinoSimona  Netherlands
Brent
Hi Brent, I was wondering: when do you know a regulator oscillates? I guess you need an oscilloscope to find out or maybe you can describe how it deteriorates the sound (in case of analog stage supply)? I have not any experience in hearing if a regulator is oscillating or not. Thanks.
Old 12th February 2012, 09:15 AM   #17929
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz CD63 & CD67 mods list
Hi guys, just checking in. I've been busy at work and not had much time to tinker with the 63. I had another go at debugging my display this evening and finally figured out that the little toroid is just DOA. I'll test it first next time. Still no further towards sorting out that mains hum at full volume. Do I need to ground one end of the centre bolt or anything? I'm considering doing a regulated PSU for the servo now, as I'm guessing that will fix it.
Still no word from TentLabs here. Any luck your end, Ray?
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 12th February 2012, 11:30 AM   #17930
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Hi Ben,
I received my XO's about two weeks ago. I sent him a third reminder to info and order@tentlabs.com and a few days later they landed on the doormat. Not that I got a reply to my messages though, the radiosilence still continues. So I have no idea what was the reason for the long delay, snow-vacation, illness...??
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Marantz CD63 & CD67 mods listHide this!Advertise here!
