Marantz CD63 & CD67 mods list - Page 1791 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th January 2012, 12:52 PM   #17901
Originally Posted by UV101 View Post
Does it sound any better???
I'd be guessing that you are running a much lower va on that winding. You won't see voltage dips on a digital meter in any case. There is a reason for using a large va tx fir the servo section. It's greedy which is why the regs are getting warm!
With respect to the servo clock, you need half of the system clock if your clock can do it, you nee to send the feed to the xti or cki (clock in) pin. Check the device pin out at the start of the service manual.
@ben, id try reconnecting the servo to the original tx, disconnect the new tx from the mains and re test. Then connect the new tx to the mains only and re test. Then pair the tx output and re test. Then connect the centre tap to gnd and retest......you get the idea!!!
The base is slightly better
You are saying connect the servo supply back to the original and test with the winding to the 12V analog section disconnected
Then parallel the two windings for the 5V and servo, and test again right?
The clock I mean the clock for the decoder (16.934MHz), not the servo clock
Pin 13 is in Pin 14 is CRout
So I connect to 13 and ground 14?
Old 29th January 2012, 01:04 PM   #17902
Old 29th January 2012, 01:30 PM   #17903
UV101 is offline UV101  England
UV101's Avatar
The @ben bit was meant for Ben to help with his hum issue or at least to try and establish if it was there previously or at which point its introduced.
With respect your change, I am not aware of the spec's of the STD tx being available anywhere, but as said, I would guess that youre now running on a much lower va winding. As a matter of interest, did you previously bypass the fuses and use a large uF cap pre reg on the 5v side? These have a profound effect on the performance of the transport. I have to be honest and say it's not the way I would look to go. As said, it'll work but I'm fairly sure you'll be further choking the servo supply by using low va transformer windings. You need to keep an eye on the heat of the transformer as you could potentially be overloading the winding.
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 29th January 2012, 06:24 PM   #17904
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Send a message via Skype™ to Ben Hanke
The new servo tx is actually buzzing, so maybe that's it. I'll have to disconnect it and listen to whether it does it when not connected to the player.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 29th January 2012, 06:39 PM   #17905
UV101's Avatar
Try swapping the polarity of one of the output over and see if it stops the buzzing
Old 29th January 2012, 09:57 PM   #17906
bikeral10's Avatar
Got a bit carried away doing a hdam bypass removed resistors r613 to r616 sounds now distorted and no volume,
these are 27omn 1/4watt is that right.
newbie or what alan
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 29th January 2012, 10:39 PM   #17907
UV101's Avatar
Those are the supply resistors to the opamps. Without them you'll not have the +/-12v to power them up. I'm surprised you're getting anything through!! I would put links in instead of resistors in any case
Make sure you remove r651-654 these will isolate the hdams from the rails. If you want to isolate the headphones from the audio also remove c901&902 and hook the opamp out too to get it off the supply rails (there are no supply resistors)
Old 29th January 2012, 11:40 PM   #17908
bikeral10's Avatar
thanks ian beer takin over here il have a look in the am thx ur a star.
alan
Old 30th January 2012, 07:26 AM   #17909
Ben Hanke's Avatar
Swapped the secondaries, but the hum is still there. The player sounds great otherwise. I wonder, could it just be my op-amps having a field day because I don't have resistors between them and the output RCAs? The hum and DAC noise is only audible at high volume with no output, and I've got an extremely sensitive amp.
I fitted all three transformers and I'm enjoying the increase in detail and depth. My only other problem right now is no display again. There's not too much out there about fitting the display tx. I think I've done it correctly as per Brent's guide, but I've got nothing coming through to the regulator again. The PCB traces are really flakey there for some reason. Beer taking over here too, so just enjoying the music now sans display.
Old 30th January 2012, 06:47 PM   #17910
Ben Hanke's Avatar
One pair of display secondaries is connected to u311 and u312.
The other is connected to u309 and to u267 via a 16.4ohm resistor.
Did I do that right?
Copyright ©1999-2017 diyAudio
