Marantz CD63 & CD67 mods list - Page 1789 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th January 2012, 08:17 AM   #17881
UV101 is offline UV101  England
UV101's Avatar
For the sake of a few pence, you should replace them all!!! I cam also recommend replacing the caps in the filter section with styrene or maybe even smt pps could be an option. See post 1 for rays list. The filter mods are a definite worthwhile if you plan to retain an opamp output stage.
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 24th January 2012, 08:20 AM   #17882
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Exactly, they're cheap mods to do so a no-brainer. The audibility is quite small in absolute terms but the value is good. Good mods to wet your feet if you're not confident with the big ones ie. regs, power supplies, clocks, output stage.
Old 24th January 2012, 07:30 PM   #17883
quan is offline quan  Australia
Originally Posted by UV101 View Post
If you can do without the on/off switch Ben, you can fit a large transformer behind the transport, that way you could leave the original TX in situ?
Hi guys, i have been sticking the trafos on the back panel, it is getting really crowded. The last one to do for now is trafo for the servo. BTW-is the DOS upgrade is much better than the op-amp- LMA49720?.
Quan
Old 25th January 2012, 09:09 AM   #17884
Fidelity Audio's Avatar
The Dos upgrade is only better if you feed it with low noise regs etc. If not the sound is compromised.
Brent
Old 25th January 2012, 09:22 AM   #17885
SimontY's Avatar
The DOS is what Russ Andrews would call a musicality upgrade, rather than a fidelity upgrade. I'd agree. Clocking, regs and servo work are more important.
Old 25th January 2012, 09:43 AM   #17886
UV101's Avatar
Brent
and if you use the right components in the build!!!!
Old 25th January 2012, 09:53 AM   #17887
Well yeah that goes without saying ;-)
Brent
Old 25th January 2012, 07:32 PM   #17888
Thanks guys, well then i will go for the servo mods first then ,may be DOS later.
Quan
Old 27th January 2012, 08:16 AM   #17889
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Send a message via Skype™ to Ben Hanke
I just finished fitting a 50VA 2x12VAC Nuvotem servo toroid behind the tray in my player. I had no problem fitting it in there. I left the KI tx in for now because I don't have the dropper resistor for the display. The good news is that it works and hasn't set on fire yet.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 27th January 2012, 11:42 AM   #17890
Thanks for your replies about the filter section. I'm building the DOS board and I just ordered a pair of mundorf output caps and two super regulators. The whole idea is to make the DOS the output stage of my behringer SRC2496 and I'm almost there. I hope the results are good after all the effort. I'll post some pictures when I'm done.
Ben: Good news you managed to fit the tx, I'm curious to hear your improvements soundwise.
Copyright ©1999-2017 diyAudio
