Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 13th January 2012, 02:20 PM   #17831
Honda Z50M is offline Honda Z50M  United Kingdom
Honda Z50M's Avatar
Thanks as per circuit then, I wasn't sure going by the names thinking source should connected to teh source rather than being the source.
(had all the parts since last May only started building it last night)
One more question gnd on the circuit is that chassis gnd or is there an 0V/gnd on the player board to connect to?
Appreciated
Tom
Old 13th January 2012, 03:19 PM   #17832
UV101 is offline UV101  England
UV101's Avatar
I've used the top screen as gnd without issue previously!!!!!
However I'd pick gnd up from the supply smoother on the 5v supply. It's sort of the natural point for a star earth. Make sure you only have 1 gnd connection onto the clock pcb.
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 13th January 2012, 03:42 PM   #17833
Honda Z50M's Avatar
Top screen??
Where exactly is the supply smoother on 5V?
Tom
Old 13th January 2012, 04:23 PM   #17834
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz CD63 & CD67 mods list
The 5v reg is the 7805 near the middle of the board with the heat sink on it. The pin order is In, Ground, Out. The supply smoother is the big cap right next to it, connected to the In and Ground traces. The ground wire would go directly to the pin of the cap connected to the ground. That's also the pin marked with the stripe running down the side of the cap.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 16th January 2012, 08:24 AM   #17835
Honda Z50M's Avatar
Thanks chaps, hopefully time permitting will have it all done by the weekend.
much appreciated.
Tom
Old 16th January 2012, 04:25 PM   #17836
Audiohifi is offline Audiohifi  Singapore
Hi
Would like to use 63KI as transport
Mod done so far are: tent clock 16.934Mhz, Alwsr 5V regulator and some caps changed for PS
Is the servo section important ? Thinking of replacing the 8.4 Mhz clock.
The power supply 5V is regulated by 7805, original
Please recommend parts to mod to make a good transport
Sorry if these have been discussed. Quite impossible to read the longest thread
Old 16th January 2012, 04:48 PM   #17837
UV101's Avatar
The main things to do here are:-
1, Clock the servo with s dedicated low jitter clock
1, fit large 22,000uF low ESR smoothing caps on the +/- rails
1, regulate the 3 driver IC's and provide quality PSU rail decoupling
1, build a large 100+va PSU to drive this section
Yes its ALL very important!!!
Old 17th January 2012, 05:53 AM   #17838
Thanks UV101
"build a large 100+va PSU to drive this section" you mean the 5V, ie from 7805 reg onwards?
Are the 3 driver ICs already supplied with regulated ps?
Thanks for assisting in my mod
Old 17th January 2012, 06:15 AM   #17839
Ben Hanke's Avatar
The drivers are 12v, unregulated. I can definitely recommend the "Search this thread" feature if you don't want to read the whole thing. It's helped me a lot. There's a lot of information in here and it'd be a shame to make Ian have to repeat it all :-)
Brent has written a useful step-by-step upgrade guide here: Marantz CD63 upgrade guide. It starts with the servo section.
Old 17th January 2012, 07:24 AM   #17840
UV101's Avatar
Lol thanks Ben
If you dont already have the service manual, go to post 1 by Ray and follow the link to his homepage. You can get the manual there.
Basically the driver ic's run from the unregulated side of the +5v regulator and the equivalent for neg rails ( there is no neg reg). Replacing the main smoothing caps with v large 22,000uf low esr caps hear make a massive difference. Also you can use the unregulated rail to supply regulators connected at each driver ic pin. With respect to the transformer, that would be when you build a dedicated psu for the driver ic's running at +/-12v regulated and supply them from the new psu. I'll see if I can find the relevant posts later
Marantz CD63 & CD67 mods listHide this!Advertise here!
