Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 5th November 2011, 02:11 PM   #17651
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
The AK4393 does need an analog output filter, see page 18 of the datasheet. The stopband attenuation is only 75dB, so some extra filtering is welcome. The suggested filter has a -3dB frequency of 70kHz, so you can use the DOS-CFP version for the SA8400, it has almost the same curve. The output voltage will be a bit lower, but that can be solved by raising the emitter resistors R9/R10 to 1k.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 5th November 2011, 10:00 PM   #17652
NinoSimona is offline NinoSimona  Netherlands
Thanks Ray, I'll use the SA8400 configuration then with the new resistor values. I guess the 15VA torroid is enough to feed the DOS board, since you already mentioned it consumed about 40mA max. with standard regulators. Now I can make a full list of parts needed, thanks.
Nino
Old 6th November 2011, 07:56 AM   #17653
quan is offline quan  Australia
Hi Guys, my remote does not seem to work that well since the mod. Is there any way to improve on it? I basically need to stand about half a meter nearby for it to work
Quan.
Old 6th November 2011, 09:40 AM   #17654
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
In my CD53 I replaced CY01 (22n ceramic) by a 10u EL and the remote now pics signal from across the room.
RC
Old 6th November 2011, 07:18 PM   #17655
UV101 is offline UV101  England
UV101's Avatar
Quan.
Check the remote batteries!!!!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 6th November 2011, 08:55 PM   #17656
Yeh ,that was the first thing that i check as well.
was thinking about that ribbon connect to the display board . The contact with IR side could be bad?
Quan.
Old 6th November 2011, 10:11 PM   #17657
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz CD63 & CD67 mods list
I've been through one display ribbon already. I wonder if it's possible to source replacements from somewhere besides cannibalizing other players? The idea of hard-wiring the display or mechanism does not sound very appealing to me, to be honest.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 6th November 2011, 10:39 PM   #17658
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
You could change it for another (new) connector and cable I suppose, but matching the correct PCB spacing would be difficult.
Old 6th November 2011, 11:19 PM   #17659
I have been checking on ebay. There are certainly similar types but not exact number of pins- the closest was 40pins type. Not sure about the spacing btw the pins.
Old 7th November 2011, 02:36 AM   #17660
Ben Hanke's Avatar
I took a quick look on Charles Hyde & Son's site and they don't have them, but on an unrelated note - they do have CD63KI toroids - I thought those were hard to get? Sharing in case anyone's interested. CHS - replacement remote controls, instruction manuals, audio & video accessories, electronic components & spare parts
Marantz CD63 & CD67 mods listHide this!Advertise here!
