Marantz CD63 & CD67 mods list - Page 1763 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 30th October 2011, 10:04 PM   #17621
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by UV101 View Post
On another note, here's a pic of the new modified CFP DOS in the player :-)
Can you please explain the mods you did to the CFP DOS ?
RC
Old 30th October 2011, 10:55 PM   #17622
UV101 is offline UV101  England
UV101's Avatar
Same as Brent Ricardo, CCS replaced with original resistor, all FETs and I used mica caps and uprated coils on the filter. :-) As I say, Brent went through it all on here a few weeks ago. I will replace those ZA's with BG's as soon as I get time to recover a few!!!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 31st October 2011, 09:22 AM   #17623
nhinstruments
RCruz's Avatar
Thank you UV101
I know what brent did. Did you experiment also with the jfet CCS ? If so what are your subjective opinions ?
I agree with you that BG sound better than ZA in the DOS... But then also do Silmics II
RC
Old 31st October 2011, 10:10 AM   #17624
quan is offline quan  Australia
Hi guys , i swapped back the original xtal on servo and the 1M resistor.
But the problem persist.-sled error 12 , now in service mode P00- the sled is NOT moving outward as i press cue/review.
?focus off?spindle off?radial off?
Any suggestions
Quan
Old 31st October 2011, 03:22 PM   #17625
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
It could be a broken driver IC, it should be moving in service mode, no matter what.
You can test that by swapping two drivers and see if the problem goes with it, if you have no new driver around. But first you should check the voltages at the drivers AT THE PINS to see if anything's missing, like +/- 11V or the 2.5V reference voltage.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 31st October 2011, 07:27 PM   #17626
6h5c's Avatar
Hi Ian,
How do you like the sound of the 'new' DOS?
Ray
Old 31st October 2011, 07:42 PM   #17627
Ray
Thanks Ray, i will test the driver IC.
Quan.
Old 31st October 2011, 08:29 PM   #17628
Look like Q105 is dead. The voltage ref on inputs A registers 0, the Vcc/Vee-measures 0.03V and power supply at input is rock solid 12/-12V
Need to check farnel for parts now.
Old 31st October 2011, 10:36 PM   #17629
UV101's Avatar
Originally Posted by RCruz View Post
Thank you UV101
I've not tried so far. Been a exceptionally busy again. I will get round to playing with the DOS configuration eventually!!
Hi Ian,
Ray
Hi Ray, the player is not quite right yet. This build is from scratch and so there is a lot going on and many new components. I'll will say it sounds very promising. Very detailed and dynamic. definitely lost the harshness I didn't like in my previous builds. As you know, I have one of the last original DOS boards too. In time I will test back to back with identical PSU and report.
Old 1st November 2011, 01:07 AM   #17630
How do you mount those cfb dos-boards? as i don't see mounting holes.
How much current do they use aprox?
Copyright ©1999-2017 diyAudio
