Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 24th October 2011, 07:34 AM   #17591
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
Ben
I don't have any bypass caps under my BG's at all as I found they made the sound worse too.
Brent
Old 24th October 2011, 03:51 PM   #17592
GHEORGHES is offline GHEORGHES  Italy
You're right. I was also very vague in my post. My problem is this. On the CS4398 DAC for my Marantz CD6003 on pin 26 is the capacitor C756. The value is 3.3 50V. I could use a 50V with a value of 10? (BG n).
I wonder why I read the datasheet for the CS 4398 that the filter capacitor on pin 26 is very critical.
I also have another question for more experienced than me. For a dedicated power supply to the DAC CS4398 , 7VA are enough? I ask this because I want to use the 'clock PSU 9v 7VABy Fidelity Audio. Fidelity Audio : clock power supplies psu
thanks
Old 26th October 2011, 12:45 PM   #17593
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Hi Gheorghes,
Nice work, you managed to squeeze quite some stuff in there!
C756 provides decoupling for internal circuitry, so by critical they mean you have to use a good cap, and the shortest possible connection so there's no additional noise introduced into this pin. Is it a standard electrolytic in there now?
3.3uF is the value that is sufficient for good operation of the DAC, but a larger cap means less ripple most of the times, so maybe a 10u BG with it's low impedance will improve things further. Just use your ears! Another good option is a 3.3uF film cap, like Wima MKS. They have even lower ESR and have very low leakage current, which seems an important factor at this particular pin.
So the verdict is: bypassing a good cap is a bad thing
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 27th October 2011, 06:53 AM   #17594
Hi Ray
Thanks for your advice. Yes C756 Is a standard electrolytic now.
You can help by answering my second question?
For a dedicated power supply to the DAC CS4398 of my Marantz CD6003 , 7VA are enough? I ask this because I want to use the 'clock PSU 9v 7VA By Fidelity Audio. Fidelity Audio : clock power supplies psu
Used as a pre-regulatet power. Now the DAC before the regulators has only 4 diodes and 1 capacitor fed from the main transformer
thanks
Old 27th October 2011, 07:45 AM   #17595
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz CD63 & CD67 mods list
Hey guys, I might have some time off on the horizon. Does anyone fancy putting these in priority order for me?
1. DAC clock
2. Servo clock
3. DOS
I have 1 flea and 1 DOS-cfp PCB ready to go, courtesy of Ray. I just need a clear focus and a definitive parts list.
Quick recap of my mods so far: CD63KI, full BG + silver mica recap, 3x Mundorf SI on PSU, Martin Clark LM317-based 5v on nearly all chip supplies, LM4562 op-amps + bypass, HDAM bypass.
P.S. Thanks to everyone who rallied to confirm what I've been hearing with bypass caps. There's a lot of conflicting opinion out there on the interwebs, but I trust my ears and you guys.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 27th October 2011, 04:19 PM   #17596
6h5c's Avatar
Originally Posted by GHEORGHES View Post
Hi Ray
For a dedicated power supply to the DAC CS4398 of my Marantz CD6003 , 7VA are enough?...
thanks
Yes, 7VA will be more than plenty to feed the DAC.
1. DAC clock
2. Servo clock
3. DOS
Hi Ben,
I think you have them in the right order, maybe 2 and 3 can be swapped. It all depends on the state of your analog output stage. But I'd say a DAC clock is most important.
Ray
Old 27th October 2011, 07:21 PM   #17597
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
1. DAC clock
2. Servo clock
3. DOS
Defo the correct order.
Adding a big tx (~50va) to supply the driver ic's is also VERY important, more so than adding a DOS, imo.
Lee.
Old 27th October 2011, 10:10 PM   #17598
bikeral10 is offline bikeral10  United Kingdom
bikeral10's Avatar
clocking dac and servo a must imho.
best gains for me.
alam
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 28th October 2011, 07:23 AM   #17599
6h5c's Avatar
HI Ray
I have the service manual cd de 6004, can be used for your site?
Thanks for the 'want to help me. Congratulations for your work!
Hi Georghes,
I checked it, and I don't have the service manual for the 6003/6004 yet. So if you'd like to share it, that would be great! Just send me a PM.
Ray
Old 28th October 2011, 09:30 AM   #17600
Hi Ray
I am happy to be useful, Which email address?
Giorgio
Marantz CD63 & CD67 mods listHide this!Advertise here!
Copyright ©1999-2017 diyAudio
