Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 24th September 2011, 12:47 AM   #17521
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
Ray I've been testing properly at home for the last 36 hours with all the changes and I have to say it is superb. I do believe it is very linear sounding now (without the ccs inparticular) and the other transistors have brought realism and that analogue sound.
Now it is offering better bass control with a small amount of extra depth. Mid range is slightly cleaner and the very uber levels of upper treble detail I used to get has improved that little bit extra too.
Ok I've had issues with this Dos but for me once some parts are changed this is the best dos pcb to date.
Ray I hope you get the same improvements I found by changing those few things. Also it is a good thing you mentioned the transistor pin out as I forget not everyone knows these things ;-)
Brent
Old 24th September 2011, 01:16 AM   #17522
I must say this! I have another marantz sa-7s1 in and of course it is a very nice cdp. It sounds superb but compared to the uber 63 it sounded very much a cheaper player. Which of course pleased me. Lee from red hill audio heard the diff and could not believe the difference especially as he really likes 7s1 (I do too)
Brent
Old 24th September 2011, 01:44 AM   #17523
I also seem able to run the cdp at higher volumes which would also suggest lower distortion. That would also back up why I have these gains. Right on time for my new amp in two weeks for bi-amping
Brent
Old 24th September 2011, 08:22 AM   #17524
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
That's beautiful! So this is with the 1k8 resistor, right? Any chance you'd try a LED CCS there, which I described earlier?
I'm still wondering why the BC560's sound so different from the 2SA's then. I had a look at the datasheet and can't find any obvious differences.
Martin, maybe you have an idea?
I guess that SA-7 needs a DOS . I'm planning to get a SA-11S2 in the future.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 24th September 2011, 08:33 AM   #17525
6h5c's Avatar
Originally Posted by gareth View Post
In respect of the clock design Ray I have also discovered another couple of designs. One is a 4007 Complimentary MOS design, another uses a 74LSxxx Schmitt device and there are variations on these too.
Cheers
Gareth
Hi Gareth,
Ok, just post them and we'll have a look. I saw the 4007 circuit before, can't recall who it was that mailed it to me. Both use CMOS gates and I don't think they are specifically low-jitter, because it looks a lot like the inverter-oscillator that is originally used in the player. But they can be built dirt-cheap, so you can give them a try and see what it sound like.
Ray
Old 24th September 2011, 01:38 PM   #17526
Chivvyp is offline Chivvyp  United Kingdom
Originally Posted by Chivvyp View Post
Got the old chip out with only 2 damaged pads. Should be able to connect those point to point if I'm careful. Just waiting for a chip to arrive from Hong Kong now, couldn't find them any closer.
New chips arrived and I soldered it in and did the point-to-point corrections. Switched it on and no output on RO. I know I said before that the issue was with LO but maybe I got it wrong before, anyway now not sure whether the issue was with the chip or not
Investigated a bit further and found a dodgy connection between pin 26 and +ve of CD16, lifted trace. Re-soldered and it's working again.
Didn't really check all the pins on the dac that when I first had the problem as I assumed if it was a power issue the whole channel would go not just half.
So, in hindsight maybe I didn't need to replace the chip but it was good practice to do and I'm chuffed that I managed it to do it.
Still think it's odd that an issue with one of the main power caps on the chip only causes an issue on half a channel, but it's worth knowing for the future.
And the players working again.
Pete
PS in the meantime I picked up a faulty 67 mkII from ebay, haven't recieved it yet but looks to be clean with just a knackered laser. Longer term it probably makes sense to think about transferring the parts to that, hopefully I'm experienced enough now not to raise so many tracks this time (I know I said that last time I did it)
Old 24th September 2011, 01:42 PM   #17527
Ray.
Yes I'm using the 1k8 rc55y resistor. I've not tried the led way but I can imagine it sounds better than a transistor. The difference between the transistors audibly is quite staggering.
Brent
Old 24th September 2011, 07:37 PM   #17528
UV101 is offline UV101  England
UV101's Avatar
I feel a bit like I'm cheating here guys! I've got all the parts available but once again due to the invaluable info published by the jolly nice folks on this thread, I'm able to short cut directly to the improved version! Anyway a big thanks all who have contributed here.
Not long now and I'll have something running to compare to the audio aero!!! Now with a spot of luck, that will be very interesting!!!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 26th September 2011, 10:46 AM   #17529
UV101's Avatar
Couple of minor set backs!!!
1st, the 10K RC55Y's were missing from the Farnell parcel :-( FOC replacements now on the way YAY!!! and I seem to have mislaid???? one of my 220uF Black Gates grrrr. How on earth does that happen. Needless to say, 3 BG's on the PSU are of little use to me.....
Now I'm just working out what I should do with respect to replacement.
Old 26th September 2011, 10:59 AM   #17530
lol
Going well then! Do you not have a BG fitted elsewhere you could pinch?
Brent
Marantz CD63 & CD67 mods listHide this!Advertise here!
