Marantz CD63 & CD67 mods list - Page 1751 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd September 2011, 07:30 PM   #17501
Fidelity Audio's Avatar
Copy away Ben. Also what the others said
Brent
Old 22nd September 2011, 07:38 PM   #17502
Originally Posted by Samuel Jayaraj View Post
2SC2240 could be replaced with 2SC1841 or 2SC1845 and 2SA970 could be replaced with 2SA992. They are more modern devices and have a very low Cob.
I used parts that I already had available and ones I had tried and tested. I used a 2SA1085 instead of the 970
Brent
Old 22nd September 2011, 09:19 PM   #17503
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Low cob sounds good, I hate it when female devices get a cob on.
Old 22nd September 2011, 10:30 PM   #17504
bikeral10's Avatar
Default cd63
Originally Posted by Ben Hanke View Post
I could never figure this out for myself. I hope you don't mind me copying your parts list when you're done, Brent?
I put 2 regs on my servo control IC last night, separating analogue and digital lines. I listened at low volume for a couple of hours and never heard it skip, so fingers crossed. I also put one on the CPU. The improvement has been pretty staggering. I plan to do the driver ICs next.
Am I missing any good places for 5v regs? I built 2 more that I am not using. I have 4 on DAC, 3 on decoder, 2 on servo, 1 on CPU.
Have you clocked the dac and servo ben thats the biggest gain imho
big caps on the psu 9 regs round the board good op amps.bout to have a go at a dos so i cant say .
alan
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 22nd September 2011, 10:33 PM   #17505
bikeral10's Avatar
Default cob on
lmao @ simon what till youve had 25yrs of it .
alan
wait even pissed again
Old 22nd September 2011, 11:45 PM   #17506
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Send a message via Skype™ to Ben Hanke
Hey Alan, I've not clocked anything yet but I'm moving up to it slowly. I bought a Flea PCB from Ray. Are two separate clocks preferred, or is it better to divide the DAC clock by two?
I have big caps on PSU and the 10 regs I mentioned, plus I'll be doing the driver ICs. I have good op-amps (LM4562HA bypassed with film caps).
Idle disc spinning is getting faster the more I take off the main 5v regulator... not really causing problems, but odd :-/
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 23rd September 2011, 02:19 AM   #17507
Ben Hanke's Avatar
Originally Posted by RCruz View Post
Did you increase the caps values after the main 5v reg in your cdp ?
C815? I think I have 4700uF there. Is that too much?
Old 23rd September 2011, 02:54 AM   #17508
Originally Posted by Fidelity Audio View Post
This is now my current configuration. The 2SA1085 and 2SC2240 have really improved the sound.
Brent
I've been gone a few days, just getting back now.
I see you are still going with the CFP configuration. Your comments back to me seemed directed to the current sink, which never seemed to matter much to me vs. the resistor. But the CFP does.
You have one of my boards, though I do not know if you are using it or one of Ray's, but my board is done with a Pin 1 Emitter on the CFP transistor, and not Pin 3 Emitter. This makes a big difference!!!!!!
Moving on, as you seem to be in experimental mode............
You are using 2mA thru the CFP. Have you tried going with 4mA, either paralleling the resistors or reducing them about in half. I use 4mA to feed the added transistor. I don't know if it all makes much difference, but thought I'd mention it.
That's all for now.
Old 23rd September 2011, 07:36 AM   #17509
Yes it's the CS I've omitted due to the reasons mentioned earlier. It is Rays pcb I am using. The transistors I have fitted are now pin 3 emitters
I'm not really in experimental mode, just tuning the sound back to what I had with the old dos. I have not changed values to alter the current (yet) as I've been getting rid of the problems with the sound I had. I may try the resistors you mention as I want to fit metal foil there instead of the Takman carbon.
Brent
Old 23rd September 2011, 09:13 AM   #17510
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
I'm using one of your boards which I got from Brent.
Do you have the schematic for this layout please? It'll make it easier for me to figure out what goes where.
Lee.
Copyright 1999-2017 diyAudio
