Marantz CD63 & CD67 mods list - Page 1748 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th September 2011, 09:39 AM   #17471
UV101 is offline UV101  England
UV101's Avatar
Originally Posted by 6h5c View Post
Hi, i'm back
Good to see there's plenty DOS-talk around
Seems the current sink needs some experimenting? Theoretically, it should be an improvement over a resistor. Maybe i'll implement a transistor-LED version in the next batch of boards, just like the one in the input stage. This would be even more versatile, and more easy to tweak to the correct current.
I'm glad you sorted out the sound now, Brent and others. Is it possible you guys could test the board with such a current sink? It's fairly simple to do: replace the FET T7 by a BC550C, replace the 100R resistor (R13) by a LED and insert a 10k resistor from the LED's anode to the +12V. R14 sets the current, it should be around 100R for 10mA to flow through the output buffer.
If you want to do it really quick-and-dirty you could even use the LED's voltage from the input stage and tie T7 base to T5 base .
Ray
Did you try with and without Ray?
Also, did you see my question about the transistors used? Could a BC640 be used in place of the 560?
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 20th September 2011, 11:58 AM   #17472
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
No, not yet. I'm just back from my holiday . It was horrible, no wireless internet in the forest
Plus that i'm happy with the sound of the CFP-DOS so far, in my SA8400. But that doesn't mean there's no room for improvement
The BC640 is a 1A-current device, with much lower gain than the BC547...560 series. Not recommended. But you could use the BC556, 557, 558 or 559 as long as they are 'C' class with high gain. The 549/550 and 559/560 are low noise, that's why I picked them.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 20th September 2011, 09:15 PM   #17473
bikeral10's Avatar
My cd52se has stopped working?
disc spins laser trys to focus but no toc keep getting error P122 any ideas.
cheer guys alan
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 21st September 2011, 03:59 PM   #17474
gareth is offline gareth  Wales
gareth's Avatar
I noticed on the previous page that there was mention of valve output stages.
There are some well designed professional (studio) grade pre-amp's on the market using 12AX7 valves. These pre-amps come with the usual line-level (and Hi-Z Mic) inputs, phase adjustment and Class A/B variable biasing if you want to, amongst other pro grade adjustments.
These pre's start at around the €40 and go up to €400 depending on what you are looking for. I know they may be a bit over board but I was wondering if anyone had tried something like this on their output stages ?
All the valve heater circuits etc are sorted for you and some offer Class A - B variable output biasing and other pro-grade options for tweaking. Anybody got any comments on this ?
Cheers guys
Gareth
Old 21st September 2011, 04:12 PM   #17475
gareth's Avatar
Stupid idea maybe ?
I liked the fact that you could get to try the valve, albeit after your own existing output devices/circuitry, sound and they are well designed and built and some of them are really rather cheap to buy, with the option of tweaking too.
Old 21st September 2011, 04:19 PM   #17476
gareth's Avatar
Ray 6h5c,
I had scanned that clock design in to the PC the other day, choice of .jpg, .pdf (through Adobe) to send over to you but someone has deleted them but I will get them scanned back in a.s.a.p. and forward it to you.
Old 21st September 2011, 08:06 PM   #17477
6h5c's Avatar
I tried that once, I used a differential stage with a double triode instead of the two FET's of the DOS. It sounded very nice, but I dare to say that the solid-state version sounds at least as good. Given the fact that tubes need a high voltage supply (= extra transformer) and a heater supply (= another extra transformer) and the solid state version runs on a comfortable +/- 15V or so, I chose the FET's. But it looks very cool
Ray 6h5c,
Doesn't matter what file-type, as long as it's clear
Ray
Old 21st September 2011, 08:09 PM   #17478
6h5c's Avatar
cheer guys alan
P122 is a bit general, isn't there a specific error number in the display? There's a list in the service manual, maybe this can point you in the right direction.
Ray
Old 21st September 2011, 08:10 PM   #17479
Malefoda's Avatar
Send a message via MSN to Malefoda
And at that time a kind of second sight has shown you the next type of caps you may offer to your dearest...
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, TDA1387, UCD400, JBL 4313B: music!
Old 21st September 2011, 08:49 PM   #17480
6h5c's Avatar
Sorry, they are not for sale
Copyright ©1999-2017 diyAudio
