Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 19th September 2011, 02:24 PM   #17461
UV101 is offline UV101  England
UV101's Avatar
I'll definitely try with both and report my observations. My player is pretty advance now with 24 decent regs ( like SPower) including 6 on the dos (when I build and fit it!!!).
Just need to speak to Lee about some 2sk170's and I'll have everything I need!!! Can borrow some off my old dos to start with ;-)
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 19th September 2011, 04:28 PM   #17462
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz CD63 & CD67 mods list
Looks great, Ant. I copied your dual stripboard layout to build mine - I found that really helpful - cheers.
Ricardo, yes I did increase those cap values a few months ago. Perpetual motion only started after fitting the decoder regs, but it's possible something else happened in the process.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 19th September 2011, 08:41 PM   #17463
UV101's Avatar
Is there any reason for using BD560C on the CFP pair?
Could I use BC640 for example? How would this effect things?
Old 19th September 2011, 09:51 PM   #17464
bikeral10 is offline bikeral10  United Kingdom
bikeral10's Avatar
hiya brent, simon.
looking@ a valve ouput stage any thoughts just rebuilt a pair of radfords sta25 i had.
valve verus dos do like the lm4562s tho .
cheers guys alan
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 19th September 2011, 10:01 PM   #17465
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
I don't think I've ever heard valves in a CD player! If you have no fear of the dangers, go ahead I say, maybe some of the emotion the cd63 sometimes lacks will come back.... or not.
Old 19th September 2011, 10:05 PM   #17466
nad is offline nad  United Kingdom
Thanks - no problem, glad to be of use (cheers Martin).
Old 19th September 2011, 10:07 PM   #17467
UV101's Avatar
I put a musical fidelity X10D clone on the back of my TDA1541 and it was crap!
With valves, it very much depends on the design. unless you are using top flight implimentation, it wont work.
My Audio Aero has a valve output stage and although its very very good, I'm still not 100% convinced.
Go DOS in the 63 with decent components if you want something special. Rays boards are pretty cheap. Thats the route I'm taking :-)
Old 20th September 2011, 06:47 AM   #17468
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
Personally I do not like the sound of valves at line level. Some areas they are very good but lack in others. They sound nice in amps as long as the quality is there. Icon audio stuff always sounds well especially diving some old quad electrostatics.
Dos is the best option for me.
Brent
Old 20th September 2011, 08:24 AM   #17469
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Hi, i'm back
Good to see there's plenty DOS-talk around
Seems the current sink needs some experimenting? Theoretically, it should be an improvement over a resistor. Maybe i'll implement a transistor-LED version in the next batch of boards, just like the one in the input stage. This would be even more versatile, and more easy to tweak to the correct current.
I'm glad you sorted out the sound now, Brent and others. Is it possible you guys could test the board with such a current sink? It's fairly simple to do: replace the FET T7 by a BC550C, replace the 100R resistor (R13) by a LED and insert a 10k resistor from the LED's anode to the +12V. R14 sets the current, it should be around 100R for 10mA to flow through the output buffer.
If you want to do it really quick-and-dirty you could even use the LED's voltage from the input stage and tie T7 base to T5 base .
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 20th September 2011, 08:31 AM   #17470
UV101's Avatar
This is the X10D clone in the CD960. I upgraded all the elco's to larger value panasonic FC and replaced the film caps with Mundorf Supreme (after this picture was taken). The main output caps were mounted on the back of the player and were rather large 4.7uF supremes! The valves were cryo treated but I cant remember which ones! The I/V was burson with simple mica/RC55Y feedback filter. That was it from the DAC out. I tried with and without the valve stage and binned it off in the end. I stayed with just the Burson I/V & filter for everything I did with the various TDA1541 output stages since.
The Aero uses minature 6021w valves and the design is much better but still falls somewhat short of what most valve enthusiasts would call "good". Mine is not the factory SE but I've got the 0.22uF supremes alone with replacement std valves and several opamp changes to the output circuit. I've also just ordered a couple of relays so I can remotely switch the whole valve stage in and out.
Marantz CD63 & CD67 mods listHide this!Advertise here!
