Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 31st May 2011, 10:57 AM   #16501
Chivvyp is offline Chivvyp  United Kingdom
Originally Posted by shepperd View Post
It may sound dumb but the cosmetic change seems to have a psychological effect on how I perceive the sound!
Well known fact - something you've done yourself always sounds better than something someone else did (even if it doesn't!)
Old 31st May 2011, 11:44 AM   #16502
shepperd is offline shepperd  France
True enough! It's not really finished as long as you can see the board! I seem to remember I asked Brent about the CTP mod but he was non-commital at the time. I presume this is the add-on to the DOS board? I'm like a parrot: I can use the words without knowing what I'm saying! Well at least I figured out how to up-load photos all on my own!
Old 31st May 2011, 12:33 PM   #16503
Cola is offline Cola  Singapore
My display panel light is flickering, does anyone has any idea which component is the cause of the problem?
Old 31st May 2011, 01:06 PM   #16504
Back to reality
Old 31st May 2011, 05:01 PM   #16505
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Originally Posted by Chivvyp View Post
I'm using 680 for R7/8 (nearest I could get) with 1K5 for R3/4. Maybe that explains it.
Pete
Yep! If you lower them a bit, the output will be higher and vice versa. But don't make it too small or the signal will clip eventually.
That will probably be the flatcable between the front panel and the main PCB. They fail pretty quickly because they are not made to be inserted so many times.
Nice pics Shep!
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 31st May 2011, 05:08 PM   #16506
Thanks Ray. More to come. I'm gluing the last piece of lead to the bottom as we speak.
The wood needed a tiny bit of adjustment. Done. What's the CTP mod? I forgot
Old 31st May 2011, 05:41 PM   #16507
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
CFP mod for the DOS
Now that you know, you msut do it, all of you guys.
Ray did yours improved as much as it did on my player? Or the super regs were also needed? I feel like the only one to find that to be terrific...
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Old 31st May 2011, 05:54 PM   #16508
So why is it also called CTP? Anyway I do have Ray's DOS. as you can see from the pictures. I know they are repeats but the light is slightly different.
Old 31st May 2011, 05:59 PM   #16509
Malefoda's Avatar
CTP? For me it stands for Computer To Plate, a former job... we are talking of the CFP for the original DOS, you DOS is not with CFPs, isn't it?
Old 31st May 2011, 06:24 PM   #16510
Ray??? where are you when I need you! so I don't look as foolish as I am.
Marantz CD63 & CD67 mods listHide this!Advertise here!
