| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#1601 |
#1602 |
#1603 |
#1604 | |
One Seriously Addicted to Audio and Electronics
Nice photo's, good job. That reg PCB looks very neat. I was just looking into some regulator data, cause i'll be doing some separate regs too in a while. Still haven't decided on what regs to use. Isn't the noise for these regulators (LM/LT1084...86, LM317) a typical 0,003% of Vout? That means 150uV at 5V out, while a standard 7805 does 40uV. Regards, Ray. |
#1605 | |
I also have some plastic caps to fit across the caps after the regs. Brent |
#1606 |
Hi all
Hope this isn't a stupid question. I am getting ready to order the brownbog pcb's for single to dual using OPA627&OPA132. Here is my question do you use 2 opamps pre pcb? Because the OPA2604 are dual opamps the ones that are in there now. Regards Dave |
#1607 | |
I'll look into the datasheets a bit more. Noise spec's aren't everything. Maybe output impedance or ripple rejection has something to do with it. But i've heard it before, that low-drop reg's sound better. I'll keep it in mind Regards, Ray. |
#1608 | |
There's no such thing as a stupid question, unless you know the answer already The two opamps in the player are dual opamps, with two identical opamps in one 8 pin housing. So actually there's four of them. Q605 is used for the left channel, and Q606 for the right. The first half of each chip (pins 1, 2 and 3) is used after the DAC, and the second half (pins 5, 6 and 7) is in the analog filter. With dual opamps you always end up with the same opamp in both places, and that's not optimal. But the adapter enables you to use two different single opamps in a dual socket on the PCB. To use OPA627 after the DAC and OPA132 in the analog filter, is a nice combination. For each channel you need an OPA627 and an OPA132 (both SMD of course), and a BD adapter. Place the OPA627 in the position of IC1 (on top) of the adapter. Place the OPA132 in the position of IC2 (bottom) of the adapter, that's it. Look at the dot for the pin 1 mark, and make sure you place them the right way around. So each adapter indeed holds two different single opamps. Regards, Ray. |
#1609 |
Hey thanks Ray
I am glad I didn't order the opamps yet I was looking at the opamp chart and it got me thinking so I thought I better make sure that there was two for each channel. I will post my results when I get them clock card will be here next week also. |
#1610 |
Yep, 2x dual = four singles! Ok, keep us updated with the results. Personally I like this combination very much. An external clock will bring a lot of improvement also.
Did you notice you have a smiley in your signature Ray. |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Malefoda |
| Page generated in 0.24305 seconds (62.76% PHP - 37.24% MySQL) with 11 queries |
