Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 21st February 2011, 07:26 AM   #15791
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
Without a doubt.
Brent
Old 21st February 2011, 07:53 AM   #15792
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Originally Posted by rowemeister View Post
Without a doubt.
Brent
Yep, I agree.
A properly sorted servo section brings much better bass and a more cohesive relaxing and realistic sound. More "analogue".
Lee.
Old 21st February 2011, 07:56 AM   #15793
You can do the 63 without regulating and/or with regulating the servo driver psu, of course regualiting improves further. The one thing that needs sorting regardless is the psu. Disconnecting the tx for the +/- 10V is required and fit in the player a 2x 12V 30va - 50va tx to supply these rails. It makes a massive improvement. You can then run the regs at +/- 12V dc
Brent
Old 21st February 2011, 10:50 AM   #15794
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
I have a dedicated psu for the servo chip with local sregs and a clock but i did not regulate the drivers. I had a misfortune while doing it and blew one of the driver opamps so I decided to leave them alone... The pcb is quite damaged in that place. I am sorry I did not know better in those days
I will keep it in mind when I get another cd53 to work on.
Old 22nd February 2011, 10:36 AM   #15795
barry.childs is offline barry.childs  United Kingdom
barry.childs's Avatar
Originally Posted by Stabby View Post
Guess that's the best solution, though I'd like making one.
I've already tried a couple stereo system remotes though. Doesn't work...
Stabby, If you still want that cd63 remote, message me your address and i'll put it in the post. I don't want anything for it. I never use them. I send the wife to change tracks!
Old 22nd February 2011, 11:48 AM   #15796
nhinstruments
RCruz's Avatar
You send the wife to change tracks... that is..... ummm strange ... the least I can say
Old 22nd February 2011, 10:58 PM   #15797
AceFactor is offline AceFactor
Think I may have bitten off more than I can chew guys! Still cant seem to get the unit to power up at all, also the solder I bought through eBay doesn't go shiny after use, its more like a dull silver...its supposed to be multicore branded 4% silver.
Tried the mains input but no luck. Just to check the neutral (blue) should be soldered to cold and the live (brown) should be soldered to hot?
Running out of ideas and thinking that this might not have been such a good idea after all!
Adam
Old 22nd February 2011, 11:15 PM   #15798
bikeral10 is offline bikeral10  United Kingdom
bikeral10's Avatar
Hi guys,
Shorted the fuse holders out 22,ooo uf caps on the psu what a difference players came to life punchy bass tricky fitting the caps in tho [extended wires and a glue gun ) .
cheers alan
Old 22nd February 2011, 11:18 PM   #15799
bikeral10's Avatar
Adam
What you doing adam iec conversion,
CHEERS ALAN
Old 23rd February 2011, 12:10 AM   #15800
Adam, did you check that on/off switch. Is power getting to the transformer?
Marantz CD63 & CD67 mods listHide this!Advertise here!
