| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#15511 | |
Regards Barry |
#15512 |
I got a few kicking about too! worth a look me thinks! thanks
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk JA-88D Class A, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
#15513 |
After the player is on for a few minutes if I change tracks or use the Random button I get the "ERROR" message. Have changed all of the electrolytics on the servo board and that made things a lot better but it is still a problem. Have also changed the bi-polar .68uf to poly at the same time that I upgraded the electrolytics on the servo boards. I have seen comments regarding grounding problems, but they were not specific as to which board or to specific components. Any recommendations would be appreciated.
#15514 |
tried the strip and clean no avail fitted a new laser from china worked first time bit of soldering fired up all good
alan |
#15515 |
Hi Gurus
Pardon me for my super newbe question. I have made lots of upgrade to my CD67 like changing the caps, opamp, diodes and clock. Recently after I have bypass the HDAM, output caps and cut off the headphone output as discussed here, my display refuses to light up even though the buttons are working fine. I have checked the voltage output from regulator 79M18 and it measure 0.6v. I have also trace all the way to the transformer and it measures 0.6v as well. I have also tried to replace the display board and still not working. What could be wrong here. I would also like to know how to measure the output voltage and impedence of the CDP correctly. I have tried to stick in the DMM to the cold and hot output of the RCA and it measures 0.06v and 0.32v for the L & R channel respectively with the CDP playing. The output impedence was measure at close to 50 ohm and 150 ohm for the L & R channel repectively. Why is there such a wide discrepancy on measurement and there is no impact on the centre soundstage? |
#15516 |
hi cola,
read earlier on in this post i think one of the other guys had the same problem 99% sure its something that you have removed cheers alan
#15517 |
Michael, I wonder if you could have a laser tracking problem or grease on the sled. Sometimes they will play ok if left to run, but cause error if you try random or track change. Just a thought!
#15518 |
I notice almost every company are using these stupid gold plated sockets now. What a shame it is only the earth, that has a huge contact area and not the 'live' pin that has a small contact area that is gold plated!
#15519 | |
Magneto the Gravity Man
Marketting !!!!!!! Andy .
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#15520 | |
Thanks |
