Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#15401 | |
#15402 |
Not 100% decided yet! I've run several types on various incarnations of 1541 output!
I have a resitor IV into a tube stage option that I got at the same time as the other PCB's in the pic. My CD960 currently uses a single burson IV with a feedback filter and an adjustable CCS to offset any DC on the output (removing the need for DC blocking caps on the output) I really like the fully discrete, zero feedback with a DC servo (again removing the need for DC blocking caps on the output) used in meridian stuff. What I'll probably do is use a basic opamp IV (single ended with 1.8k and 2n2 feedback) and DC blocking caps to start then when I've built the tube stage, have a go at that but if I'm honest, fully discrete zero feedback is probably the way that I will go! I know Simon and Lee have had some really good results with Pass Labs D1's and if i'm honest, i'll end up having a play with that too> Attached is a basic opamp IV which will pretty much outperform anything you'd find in a comercial player (unless its discrete!) If you add a ccs before the opamp, you can tune the DC voltage to 0 then remove the blocking caps and then you are starting to talk...... ![]()
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber ![]() ![]() |
#15403 |
THANK YOU! Tom, Brent & Ray.
#15404 | |
Sorry for the offtopic |
#15405 |
I love my Pass D1 stage, very musical
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#15406 | |
nhinstruments
I also use spowers in my Meridian 101 preamp.... Salas shunts are too big and generate too much heat for these purposes.... otherwise I would try them to evaluate the differences. Apart from size and heat there are other big differences .... I can build them p2p (I have built 20 of those).... Salas shunts respond very well to component changes anabling me to tune them to fit the rest of the system. I can not build Spowers ![]() |
#15407 |
Hi Ricardo, I was refering to that fact that the DAC i'm building isn't operational at the moment! I'm hoping that I will get a chance to get it going very very soon as I believe it will be awesome!
Edit - Page number 1541 of the tread!
#15408 | |
I've got the Salas shunt working at 5V, which are the sound-critical 5V lines to add the reg to? I believe U200 and U174 are the DAC 5V lines, but which other links do I need to tap in to? |
#15409 |
You should start to isolate all the 5v supply rails accross the player thats why most of us run multiple regs. 2 on the DAC, 3 on the decoder, 1 for the HF amp area...........the list goes on. Even loads of 7805's is a massive improvement!
On the DAC, there are 4 Analogue supply pins (17,21,22,26) these can be fed from a single point (U200). Pin 16 is the digital psu line and can be traced back to RD04. If you are running multiple devices from the same regulator, you should use a small resitor in line with each supply (thats exactly what RD04 is). If you look at the 1st few posts in this thread, you'll see the mods list from Ray with suggestions for inductors with ferrite beads instead. Personally I prefer separate regs for everything then you can do away with the resistor/inductors. Remember, the more lines you add to the single reg, the more noise transfered between all the connected devices. As the CPU is noisy, a good mod will be to get that onto its own 7805 just to get it off the other rails. Spend some time familiarising yourself with the manual, you'll soon pick out the 5v rails and see where you can start to seperate. RE U200 -For the analogue supplys, use something like Rubycon ZLG or ZA (or Black Gate if you fancy) to replace the decoupling caps CD15 & CD16 RE RD04 - For the Digital supply, use an Oscon SEPC or Nichicon solid polymer to replace CD07 Dont worry about increasing the values to either!! I run 470uF for most local decoupling!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber ![]() ![]() Last edited by UV101; 18th December 2010 at 03:08 PM. Reason: additional info |
#15410 |
One other thing! The large benifits of running a decent reg on the DAC analogue (U200) will be lost if you start adding everything else to the new reg.
You should listen and make your own mind up but in my experience, digital rails are noisy. When you add a nice clean supply just to the analogue DAC rail, things will improve, if you then add the DAC digital with its noise to the same reg, you will transfer that noise the the analogue side. Dont take my word for it!!! try both and see what you think.....
New To Site? | Need Help? |
