Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th November 2010, 01:53 PM   #15121
Malefoda's Avatar
Send a message via MSN to Malefoda
Yep I guess that PCB is not the same. It's easy and quick to change it.
About laser unit, soundwise, VAM12 vs CDM12 and even old but working CDM12 vs brand new VAM12?
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music!
Old 15th November 2010, 07:31 AM   #15122
Fidelity Audio's Avatar
You don't need any dc blocking caps in the 63/67. The only noise you will hear is on power on/off where the +/- psu discharges. This is where you build a simple muting circuit to stops this happening.
Other than using caps like Mundorf Supreme or better you will always add colour or grain to your sound.
Brent
Old 16th November 2010, 12:27 PM   #15123
tms2000 is offline tms2000  Singapore
Do you need to change the value of R655,R656,R660 & R661 when replacing the dc blocking caps.I like to try blackgate N 47uf, please tell me the value of the resistors above.THANKS
Old 16th November 2010, 05:49 PM   #15124
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
No, you don't have to change them. They just provide a (dis)charge path for the output caps, in case you power-up the player without an amp connected.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 17th November 2010, 03:11 AM   #15125
Ray
THANK YOU! I ask because it seem to sound thin (bass is lacking)
Old 17th November 2010, 05:27 AM   #15126
6h5c's Avatar
Oh, that could be the Black Gates. They need about a zillion hours to burn in...
Don't worry, the bass will probably come back in one or two weeks, depending on how many hours you play music every day.
Ray
Old 17th November 2010, 11:10 AM   #15127
Ray
So it's not because I lower the value (from 110 to 47uf)THANKS again
Old 17th November 2010, 12:05 PM   #15128
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
No, certainly not, at least not from a clear technical standpoint. You'd probably not get bass roll-off unless you reduced it by a factor of 10! Most people use about 4.7uF and have decent bass.
Old 17th November 2010, 01:30 PM   #15129
I have yet to find 4.7uF cause a problem on the Marantz output. 2.2uF causes bass roll off on some systems.
Brent
Old 17th November 2010, 01:36 PM   #15130
barry.childs's Avatar
I used 4.7uf and the bass is good. Iv'e been told by many people not to go lower though. I removed the muting transistors in one cd63ki but could hear no improvement so I put them back.
Page generated in 0.69701 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
