| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#1501 |
Magneto the Gravity Man
Hi.
Ideally, ferrites / chokes should be positioned right next to the chip. [ minimum distance ] Andy |
#1502 | |
#1503 |
two of the many !!!!!
I still have 6 left plus the '43, '53 and the numerous CD60, Seimens RA400, Kenwoods, CD303. CD104s, cd304 [1+2] etc Oh, I forgot - the CD4000 and the 2 B&O CD-X you can't move in my garage ! |
#1504 | |
#1505 | |
Didn't I mention the CDM's ? or the CD204? |
#1506 |
Would it be possible to feed the PWM outputs into a half-bridge amplifier MOSFET stage, and LPF ? Then I wouldn't need an amp ! http://users.ece.gatech.edu/~mleach/...01/ClassD2.pdf Or have I had too many beers! |
#1507 | |
Hi. Since the balanced inpt power amp is essentially the same as a balanced input op-amp, the answer is a [ guarded ] YES ! How about incorporating a T-AMP or TDA1554 and psu inside the chassis? Andy |
#1508 | |
TDA1554 looks interesting, and is quite cheap. [url] If I added sockets in the Marantz and it all went wrong I could put the old op amps back in. T-AMP- might get one of them since I got paid today. |
#1509 |
FAO RAY......
Ray as you know I have the OPA627 and OPA132 combo on browndogs. I have not done any bypassing on them yet. And now is the time lol I have the two Audiocom super regs directly on the op amps and 4 Black Gate FK 16V 470uF caps. The noise should be pretty low, so do you still recommend I need bypassing on the opamp pcb? I was looking at using BG FK 16V 33uf or 47uF caps or do you recommend a different value you have found works better. Also something like a 220nF film resistor to decouple + and - 12V, is this also advantagous. cheers Brent |
#1510 |
Hi Brent,
How close are you going to put these caps to the opamps? Can you get them on the browndogs? Cheers, Phil |
| Currently Active Users Viewing This Thread: 4 (3 members and 1 guests) | |
| mikvous, hejira858, Puffin |
| Page generated in 0.24467 seconds (66.06% PHP - 33.94% MySQL) with 11 queries |
