Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th April 2010, 10:30 PM   #14381
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Bargain mate, well bidded
Old 29th April 2010, 06:43 AM   #14382
UV101 is offline UV101  England
UV101's Avatar
Maybe! Its a bit of a state! we'll see when it gets here.
Fingers crossed for a decent enought starter
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
Restek Fantasy, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 29th April 2010, 08:47 AM   #14383
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Originally Posted by PBZzz View Post
Next time I wil ask an expert.
Well.... some of us are really experienced in pad lifting
I just wanted to warn you about these old boards..... always be very gentle, particularly when desoldering.
Old 29th April 2010, 09:02 AM   #14384
SimontY's Avatar
Indeed, good to add fresh (tin/lead) solder, then remove that with a desoldering pump, then see if the legs are free. If they're not free apply heat and wiggle or pull slowly. With some practice 99% of pads will stay healthy this way.
Old 29th April 2010, 09:20 AM   #14385
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
So says the expert "Pad-Lifter" !!
Seriously, if you don't already own a soldering iron, get a good temperature controlled version with interchangable bits.
Then get a scrap amp / cd / radio or something and PRACTICE until you can remove and replace components without damage.
Use lead / tin solder NOT lead-free or silver solder and solder wick.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 29th April 2010, 09:39 AM   #14386
SimontY's Avatar
Just changed a TDA1541 chip without lifting any pads
Old 29th April 2010, 10:33 AM   #14387
Chivvyp is offline Chivvyp  United Kingdom
I did that as well. In my case it was mounted on a socket though
Did bend a few legs though
Old 29th April 2010, 10:34 AM   #14388
SimontY's Avatar
They're very hard not to bend!! I think prising from underneath is the way to go... Pulling out from above is bad.
Old 3rd May 2010, 03:23 PM   #14389
Sent off my 67' to Brent (Rowemeister for those who don't know his alter-ego) for a full monty: Ray's DOS board and various other gubbins and magical bits, including (finally) a good (I hope) power cord to be properly installed. Here's hoping it gets there safely and back home again. I've been using the same battered box for years...it seems to bring good luck! I'm a lazy, no good s.o.b who let's others do all the work...well some of us have two left thumbs and too many unseemly incidents with hot irons to take any more chances. Anyway this is for the pros. I will report back when it all happens. I'm chasing after Brent's cdp, and Ray's and Simon and whoever else. I'll get there eventually.
Old 3rd May 2010, 05:44 PM   #14390
SimontY's Avatar
Yours will be plenty better than my last one by the sounds of it. My recently modded CD63 is a base model and only has one extra power transformer and one S Power reg. It has lots of tweaks though and they certainly do add up!!
The Arcam Alpha I'm doing for myself, however, will not lay down and be attacked by predatory machines of a more modern era. It's rather good.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
thierry67
Page generated in 0.22889 seconds (62.53% PHP - 37.47% MySQL) with 11 queries
