| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#14291 |
Hey guys!
I'm new here, won't bother you for a long time. I'm Lars. From The Netherlands. I've got a complaint about you ;-) Just want to say, that after a long day of working [since I have a few days off ;-) ] I see at 01:15 AM local time (I can't get asleep) that my collegae at work Ray, has a thread with 14290 posts.... Unbelievable. And because I bought 6 (!!) second hand Elektor Crescendo amps last week (tweaking Crescendo's is another project of Ray), I'm now sure I can't impossibly get asleep for the rest of the WEEK, because YOU ALL keep my friend Ray to busy to help me!! Regards (and kind greetings to Ray) from The Netherlands, Lars (#14291....) |
#14292 |
One Seriously Addicted to Audio and Electronics
That sure sounds VERY bossy, Lars
Any of those amps up-and-running yet? We're into the DOS-CFP-thing over here. Ray |
#14293 |
Magneto the Gravity Man
Ray,
can you re-post your website address, please. Andy .
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#14294 | |
![]() Regards, Bossy. |
#14295 | |
Pete |
#14296 |
Of course, here it is (english version). You can also click on my public profile, it is listed under contact information.
Ray |
#14297 | |
The CFP-part stands for Complementary Feedback Pair, a tweak to the DOS circuit that replaces the input transistors by two pairs in CFP arrangement. I've just started a page for this CFP-tweak, there's not much info there yet, but I did place an interesting link about this subject. Ray |
#14298 | |
Lars |
#14299 |
Yes, there is
![]() Guys, here is a man that never heard a properly tweaked CD63/67 before You are invited to pick up a CD67 here in Heerhugowaard some day Lars, and do some listening! Regards, Ray |
#14300 |
Hi everyone,
Remember I was testing Brent's C2 clock? Well, testing is finished, and the final results are in. Slightly delayed, due to family expansion over here, but no less interesting because of that To get right to the point: the performance is very good! First a disclaimer: measuring jitter in the pico-second range is not a problem nowadays, with a suitable (expensive) analyzer. Unfortunately, the possibilities in my case were limited by the available equipment: an Agilent Infiniium oscilloscope model 54835A. Because it's functionality regarding jitter is limited, it is not possible to filter the jitter-signal. The scope will therefore display the entire jitter-spectrum, while the area of interest for audio is actually only the low-frequency portion. The results will be a bit higher because of this, and that's why this measurement is only a relative comparison. Brent has kindly donated a C2 for testing purposes, thanks again Brent! I used The Flea with a 24.576MHz low-jitter Tentlabs XO module from my ezDAC for comparison and the C2 with both 16.9 and 33.8MHz oscillators. The result: the performance of all three is very good, AND very close! From the C2, the lowest jitter clock signal can be obtained directly from the oscillator output, at point T1 on the PCB. This is no surprise of course, because at this point there is no extra logic in the signal path that can cause jitter. The outputs F/1 through F/4 show slightly more jitter, but only a little bit. The extra divider logic has an extra benefit: a nicely squared-up waveform with steep flanks, and this keeps the rise in jitter limited. I also tested the C2 in my CD63mkII-KI and clocked the servo with the F/2 output. The result was clearly audible: a more controlled low-end, more quiet background and increased soundstage depth, to name a few. So my conclusion is: the C2 is a highly recommended upgrade! ![]() Regards, Ray Last edited by 6h5c; 21st March 2010 at 10:17 PM. |
| Page generated in 0.25654 seconds (66.22% PHP - 33.78% MySQL) with 11 queries |
