| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#14261 |
Ray, i need help!!!
First hello to everyone. Quincie is my name (not realy:its Ruud) ![]() I`m a newbee with electronics, but i love great music. I have a Marantz cd67 MKII OSE and i want to upgrade this beatiful player. I looked around youre site and i love it, but here is my problem. I don`t understand a lot of your schema`s etcetc, but i want still upgrade my player. Is there anyone, or do you know someone who can do that for me. Please help meeeee!!!! Quincie. |
#14262 |
One Seriously Addicted to Audio and Electronics
Wow, it's awfully quiet here, with so little posts in one week!
Let's stir things up a little: there's a new tweak for the DOS available!! ![]() This tweak was kindly brought to my attention by Steve (stvnharr) from this forum, thanks a lot Steve! Now what is it? There's no how-to yet, only this PDF, so it's highly DIY I haven't tried it myself yet (gathering parts at the moment...) but Steve reports a major upgrade in sound. In time, there will be a page dedicated to this tweak on my website, and I will probably adapt the DOS boards to fit this tweak. Untill then, it's happy soldering ![]() Regards, Ray Last edited by 6h5c; 12th March 2010 at 07:56 AM. |
#14263 |
Yeah I noticed this thread is drying up! Ray, guess who wouldn't mind being a guinee pig for the new tweak? Surely there is some more goodness to be squeezed out of our medieval machines. Computer audio is taking over the world! fight back!
#14264 |
Computer audio? That's for the deaf!
![]() I will keep spinning discs untill the last lasunit is gone! It will certainly do some squeezing. Considering the low part count and < $1 cost, it's a must-try tweak! Ray |
#14265 |
Ray, this is timely as I'm building a dos today so I'll adapt and test this new circuit.
I'm using the dos without the preceding filter section as a discrete I/V stage in my dac and so far the test rig is working well. Is it possible to implement the filter after the summing input pair(s)? Cheers, Lee. |
#14266 |
Cool, i'm curious what your findings will be. Good timing
The filter is passive, and in theory it can be implemented anywhere in the signal chain. It will give about 6dB signal attenuation. But i'm not sure the output-side is the best place for it. The idea is that the filter clears the incoming signal of the DAC from a large amount of HF noise, so the input transistors are not affected by this. Distortion numbers will probably be worse without the filter, because this HF trash often causes TIM. Regards, Ray |
#14267 |
Thanks Ray, I thought it would be possible to do that. I realise that it will increase distortion in the input transistors, but there's no getting around that for me.
The trouble is that the current out dac (AD1853) isn't happy at all driving the filter section, so I need the current to voltage conversion before it, then the filter. I'll then add a gain stage and buffer at the output. The filter will really only be approximate because it's not specifically designed for this chip. Thanks again, Lee. |
#14268 |
Very interesting indeed. I have been talking with Lee about changing the output side of the dos to eliminate dc offset.
Combining the two could produce some very interesting results Brent |
#14269 |
Lee,
Do you use two low-ohmic resistors for I/V? Eliminating the DC will be a challenge, you will need some form of feedback to accomplish that, to have a stable 0V output. Ray Last edited by 6h5c; 12th March 2010 at 04:02 PM. |
#14270 |
Hi Ray, no I/V resistors here. I like active I/V as it always seems to sound better for me, something to do with the dac liking a constant zero-ohm load on it's outputs I think.
Unfortunately, although it worked and sounded great, using just the DOS for I/V wasn't giving enough gain, I lowered the emitter resistors as far as I could before distortion kicked in but it still isn't loud enough. After I posted earlier, I adopted an opamp I/V stage and am using the dos to sum its outputs and while it does sound really, really good, fully discrete is the only way to go. Lee. |
| Page generated in 0.22470 seconds (53.20% PHP - 46.80% MySQL) with 11 queries |
