| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#1401 |
One Seriously Addicted to Audio and Electronics
My first impression is: yes.
It's much solid-state-with-lots-of-feedback vs. less solid-state-with-some-local-feedback, and the latter wins. Maybe the next level will be to compare the sound of different types of transistors? ![]() The only drawback is that I have to go look for good decoupling caps again, since there's plenty of DC at the output now . I think i'm going to use a 2u2 Auricap for both, or maybe a BG for the transistor stage? That one can be low voltage Ray. |
#1402 | |
Brent |
#1403 | |
allan
Indecision makes the world gone round. Maybe |
#1404 |
The tubestage does between 110 and 145V DC, depending on how much current the triodes are biased. The signal is taken from the anodes, so that's obvious :-D.
The transistor stage has about 6V offset at its output. The voltage on the collectors of the differential input stage is about 7V, and that's buffered by a darlington emitter-follower, so minus 2 * Ube. Regards, Ray. |
#1405 |
Ray- can You give me a few info about Your passive filter?
#1407 |
Thank You Ray. What do You now prefer - tubs or transistors ?
#1408 |
Hi Ray,
I saw the article on ultranalog.com, but couldn't find the schematic anywhere. Surely you could have done a discrete equivalent of your tube stage? Cheers, Phil |
#1409 | |
The actual active circuit has become so minimalistic that the other components in there become much more important. So in the end I think that will play a great role in how the sound of either stage will be. Regards, Ray. |
#1410 | |
The tubestage is not taken from Ultranalog, only the transistor stage. The schematic is here on the second page of the SACD Enhancer article. I changed it slightly to get a bit more output headroom, and put the passive filter stage in front. Here's the schematic I used. But both the tubestage and the transistorstage a similar: following the passive filter is a differential input stage with current sink in the tail to combine both DAC outputs, and in case of the transistor stage a buffer for low output impedance. Regards, Ray. |
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| thierry67 |
| Page generated in 0.18933 seconds (59.01% PHP - 40.99% MySQL) with 11 queries |
