Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th January 2006, 11:16 AM   #131
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Originally posted by rowemeister
The third pin of Q801 and Q802 are the +/- 12V outputs.
The third pin of Q811 is the 5V output
When measuring make sure your common on the DMM is to gnd, Hdam can is a good place for this (ooops you removed it lol).
Measure pins 13,20,28 on ic Q104 for 5v.
Measure pins 1,2,8,9 on ic Q105/Q106 and QM01 for +/- 10V
Hmm
I could so easily short those pins. It's a bit too risky, and it means turning it on when it's not in it's box, which scares me, quite frankly.
Is there no safe way to test at least some of the voltages? Couldn't I leave the pcb in and just probe some jumpers, for example?
Will test mode show anything useful perhaps? It will certainly be the next thing I try.
Old 10th January 2006, 11:19 AM   #132
Fidelity Audio's Avatar
NO
The player will work without the DAC clock in. You will get no sound
Also the processor clock must be running otherwise nothing would work.
mmmmmm
It will be something really minor causing it
Old 10th January 2006, 11:23 AM   #133
SimontY's Avatar
Originally posted by float
HI Simon,
I remember reading somewhere that the clock must start up no later than the rest of the player (if that makes sense).
Is this still the case with your current clock power arrangements?
Dodgy clock lock will affect transport. ( I think )
Hello float,
But my clock is quite well separate from the rest and has been for years, so I really don't suspect it. I've tested the psu voltage to it, and the clock wires go well into the board. Also, when the clock is disconnected the error is quite different (from past experience) - no horrid noises (and no TOC etc.)
Old 10th January 2006, 11:29 AM   #134
The 5V reg is easy to test and so are those pins on the ic's with the pcb fitted to player.
Old 10th January 2006, 11:34 AM   #135
SimontY's Avatar
Then I shall begin by testing there at 5v.
Helpful as ever rowemeister, this is a helpful forum
Old 10th January 2006, 02:01 PM   #136
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
Originally posted by SimontY
Hmm
In test mode you can check if all the individual servo's are working.
With the PCB in the player:
- you can measure at RD01 and RD04 for +5V to the DAC and clock.
- R508 and 511 for +5V to the decoder
- R122 and 123 for +5V to the servo chip
- R136 too see if the laser gets +5V (switched)
- and all the other 4,7R resistors that were replaced by inductors
The +/- 12V is only used for opamps/HDAM/phones and muting, the player should work o.k. without it. But you can check it at pins 4 and 8 of either opamp, or at R613...616.
Good luck!
Ray.
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 10th January 2006, 02:10 PM   #137
6h5c's Avatar
HI Simon,
This is only the case with the CD57 or CD67, for those players you are right.
The decoder and servo are integrated in one chip there, that get's its clock from the DAC. If the clock's not there in time, the player won't work.
But the CD63 uses a separate servo-chip which generates it's own clock.
Ray.
Old 10th January 2006, 02:40 PM   #138
SimontY's Avatar
Good luck!
Ray.
Excellent, I will look for these parts and measure the voltages
Many thanks
Btw, can I harm anything by leaving everything powered up whilst it's in this unhappy state? Should I disconnect the drive's power or anything?
Old 10th January 2006, 02:48 PM   #139
you will soon find out!!! LOL
Its the only way to find out mate really.
Old 10th January 2006, 03:07 PM   #140
SimontY's Avatar
I could always buy another off Ebay, lol!
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
thierry67
Page generated in 0.20977 seconds (54.42% PHP - 45.58% MySQL) with 11 queries
