| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#13932 |
I just have a DIY passive capacitor filter plugged in next to it. Something like 15uF across Live and Neutral and 11uF across Neutral and Earth and a small cap across Live and Earth. It's great sonically... but it does cause a little buzz pickup on one of my sources (not a CD player) since adding the big cap across Neutral and Earth - annoying as it improved the sound!!
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#13934 |
Principles? It just filters noise.
Across live-neutral film caps rated at 250V AC. There are caps rated for safe mains use and they're classed as X2 for across live and neutral or Y1 or Y2 for across live-earth. You're not meant to connect much across live-earth as it can cause problems on your ring main. Lighting capacitors or motor run capacitors are also safe for mains use. Mine are mainly 2.0uF and are in plastic cans designed for mains use (seven of them). I also have a 500VAC 220nF film cap (very high quality) across live-neutral, plus a few VDRs to quench spikes. Across neutral-earth a smaller voltage rating is ok and I have a 10uF MKP 400VDC and a couple of others.
#13935 | |
Also there are a few other considerations to do with power factor correction that you need to consider before adding very high capacitance accoss the mains!!! Too much capacitance may run you in to trouble with you electricity supplier!!!!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk Restek Fantasy, Audio Aero Capitole MKII, Focal and Kimber |
#13936 |
Brent'll get into trouble before I do then LOL. Certain Russ Andrews products put at least 30uF across live and neutral so I feel pretty safe with my 14uF. His gear will have to pass rigorous tests to be legal to sell.
Live to earth can only be tiny, I have also read this, it's why Y-rated caps only go up to about 47nF or something. I have only used one such cap here. Simon
#13937 |
LOL! me too! TBH i don't think it makes much difference at th levels we are talking about but you are right about the "Y" class for L-E and N-E. You should never put any cap other than type Y accros to earth
See here Filter capacitor: Definition from Answers.com I think I used type Y 0.047 to earth (although i believe the maximum recommended value is 0.022uF) and correctly spec'd self healing (lots of) for my filter
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk Restek Fantasy, Audio Aero Capitole MKII, Focal and Kimber Last edited by UV101; 19th January 2010 at 09:16 PM. |
#13938 |
4n7 across Neutral - Earth and NO more.
There's a really good reason for this: if there is an earth fault anywhere upstream, a large cap can raise the case - of everything else connected to the faulty earth - to a high voltage. 4n7 limits the current, and therefore teh shock potential, to about 0.5mA - which is still a very hefty sting, but below the level which stars to become really dangerous (1mA) Equally, Neutral is a Phase conductor. Not less than Class X1(to L) or Class Y caps (to earth) may or should be used. This is non-negotiable IMO. Really big caps across L-N domestically are just a plain wasteful idea. 30uF means 2.5A of reactive current - you don't get billed for it, but it creates waste in the generation network from heat etc just like a 2.5A load would (thats 600VA...). It also does not necessarily help (acoustica.org.uk: shocking! - scroll down a bit past 'Don't try this at home'...) |
#13939 |
Is that due to the change in current phase? Do newer digital meters still rely on the 90° phase difference to measure the used electiricty? If not, you would still be charged for the useage????
#13940 |
I beleive domestic bills are only for 'real' power, they don't bill VAR.
| Currently Active Users Viewing This Thread: 3 (1 members and 2 guests) | |
| Puffin |
| Page generated in 0.23532 seconds (62.73% PHP - 37.27% MySQL) with 11 queries |
