| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#13891 |
One Seriously Addicted to Audio and Electronics
Strange. For all you know, it may have been there all the time but you just didn't notice it. With the muting gone, you can hear everything the player does when it's not playing. The hum changes when the player focuses, so it sounds like the problem is load related. A scope would be real handy to see if there's any excessive ripple on the supply lines. Also the internal ground could still be a cause. When the load currents do not run where they are supposed to, this can generate similar problems. You could do a quick check of the various supply voltages with a DMM, and see if they are not low or sagging. Also, check before the regulators, to see if the voltage doesn't fall below the minimum requirement = output voltage +2.0 to 2.5V. You may even try to measure residual ripple by using the AC function and see if you can detect any abnormal levels on the supplies.
Regards, Ray |
#13892 |
Ok that's an easy task for next midday!
Thanks Ray, Matthieu
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music! |
#13893 |
All voltages OK, grounds of outputs to DAC's one, the same. Anyway, that's the very same hum as my phono stage and alsmot at the same (far away of music level) level! More than odd...
#13894 |
Are you sure it's coming from the player then?
Ray |
#13895 |
Rien ne m'est sûr que la chose incertaine.
Will lend it to a friend for test and get a full review ![]() thanks guys for the help provided, still have to regulate the drivers before let the bird fly away. Matthieu
#13897 | |
Also, try disconnecting all your kit from the mains and adding back 1 at a time. I had a dodgy transformer in my CDP that was causing problems for my amp!!!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk JA-88D Class A, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
#13898 |
Yep Ricardo, good memory here
![]() And yes Ian, I'll unplug all and check that. Thanks fellows, Matthieu
#13899 |
Hello.
i'm back, just bought a 2nd cd67 mkII this week and would like to modify it slightly, i'm not planning to bring it as far as ny first heavily modified cd67se. Mod's planned, opamps lm4562, disabling hdam, disabling output caps and transistors, muting circuit. Just wondering if it is a good idea to re use the output caps's (c655/c658), elna silmic 220uF, around the opamps, replacing then the Elna 100uf (red) (C611/C614). Can the Elna red's be used somewhere else as well.
Hifi Setup: http://my.hifi.nl/?user=1651 Music Collection: http://www.hilbimuziekcollectie.tk |
#13900 |
Old Cerafine vs old Silmic, try one channel, maybe better bass?
I won't fit any LM4562 until they have at least clean 317/337 or it may sount boring. Why not a good AD device? My 2cts. Left red Cerafine may be moved to DAC and Decoder.
