Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd December 2009, 06:51 PM   #13761
RCruz is offline RCruz  Switzerland
RCruz's Avatar
is coming back
Old 23rd December 2009, 07:24 PM   #13762
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Merry Christmas all. Time for a well earned few days off
Lee.
Old 23rd December 2009, 07:46 PM   #13763
Malefoda's Avatar
Send a message via MSN to Malefoda
Merry Christmas to you all!
May I speak of CDP in these times of religion and christian rites?
I do!
A well modded* CD-43 vs a stock CD-53:
It's better but less than I'd expected. Or as far as I can hear it's just better. I wonder if I even can hear any difference between a CD-63 and a 63 SE...
By better: like the same behaviour but a veil impacting detail and space has been removed, some harsness also. But still on the smooth side, not on the "in your face" side.
Of CDPs and Men:
in what system may a CD-43 be used, the answer was in a budget one,
in what "level" of system may a CD-43 modded be at ease, as I hold for now that it's the systems wich won't let see what it can do in its new state.
Maybe I'm wrong and the CDPs just do few in the whole system, but I can remember I've seen new lands with high-end vaccum headphones amp and Grado headphones as when shifted from the worst Arcam integrated to a very good chinese tank.
If possible people with experience in amp/speakers dpt. make a "system target" for this kind of player if was a real product in shop? Or what stuff the player is linked to and allowed you to see these "huge" improvments?
*mods are custom Flea and flipflop for DAC & Servo reclock, dedicated PSU and nicely fitted LM317s at DAC's Analog, clock ref, Digital, Decoder's Digital and Analog, HF amp, 317/337 for drivers, Discrete Output Stage with 2x 317/337, BG at analog parts and ZL & FM around, close bypasses at ICs.
Sorry I have to leave to go to church,
Matthieu
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music!
Old 23rd December 2009, 08:59 PM   #13764
Thomo's Avatar
I have an unusually technical question (for me).
In the cd63, is the data output from the SAA7345 decoder left or right justified? I'm struggling to find the info from the datasheets.
I'm looking at fitting a PMD digital filter + TDA1541A dac into my cd63. Hopefully over xmas I'll have some time to play around with it.
Cheers, Lee.
Old 24th December 2009, 08:09 AM   #13765
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
AFAIK, standard I2S is left-justified. See the piece of text from the I2S-bus specification. MSB has a fixed position, and LSB is more or less 'floating' and depends on the word length. If it would be right-justified, this wouldn't be possible. It also states the 'MSB is sent one clock period after WS change', so it must be left
Can't imagine Marantz used EIAJ format...
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 24th December 2009, 12:13 PM   #13766
Thomo's Avatar
Excellent, thanks a lot Ray. I was thinking it was left justified, but that has made it pretty clear.
Looking at the datasheet for the decoder, it looks like it can also be used as a digital filter, so I may give that a try too
I'll keep you all posted on any progress, or lack of, lol.
Merry xmas, Lee.
Old 24th December 2009, 12:23 PM   #13767
UV101 is offline UV101  England
UV101's Avatar
Merry Christmas everyone!
Have a great one!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
JA-88D Class A, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 24th December 2009, 01:44 PM   #13768
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Lee.
Merry Christmas to all.
Days off !!!! I wish it were true !
I drew the short straw this year !
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 24th December 2009, 02:27 PM   #13769
6h5c's Avatar
Merry xmas, Lee.
It can, the decoder's oversampling function is not used in these players as it is done in the DAC. It's difficult to enable it, as this is done by the microcontroller. But don't expect too much of it, there's a reason they didn't use it
Reminds me of the first time I was tinkering with these players. I was measuring the bitclock and got 2.1168MHz, and I was like, huh? That's not 32*Fs, or 64*Fs, but 48*Fs, that doesn't make sense?? That doesn't match the 16 bit I2S output mode. Seems it just outputs 24 bits per word, and the DAC is set to 64*Fs, expecting 32 bits words, but because it's left-justified, it doesn't matter
Ray
Old 24th December 2009, 02:45 PM   #13770
Chivvyp is offline Chivvyp  United Kingdom
Originally Posted by RCruz View Post
Hi Simon
I believe you are now hearing the effect of the C505 2200pF polystyrene.
It is one of the most revealing mods I did.
Ricardo
Is the cap value very important here, do you think I could get away with an 1800pf? I have some polyprops with this value already.
Pete
Copyright ©1999-2013 diyAudio
