Marantz CD63 & CD67 mods list - Page 1374 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th December 2009, 12:52 PM   #13731
wdoerr is offline wdoerr  United States
wdoerr's Avatar
Installed servo regulator yesterday. Very nice, indeed.
Couldn't solder to the jumper, so I had to run wires, grounds too, from the bottom of the board. The first two 7805's I tried failed miserably. First I though I didn't need to scrape the lacquer of the top of the pcb, I'll just solder it to the ground of the resistor I just took out. Did it for both feeds. After I woke up, I solder bridged two pins. Then I cut those two out and installed two new ones correctly. Also, ddn't pay attention when reconnecting the ribbon cable to the front panel, and crimped a couple pins on it. Now the display does not work, which is very annoying. Definitely have to fix that.
On to the DAC.
Old 14th December 2009, 08:45 PM   #13732
What a great feeling to fix something... my machine runs again. Turned out to be that I broke a soldering pad, so the Digital Vin on the decoder had 0. Strange response of the chip to just let the motor spin at max speed.
When it aint broke, break it. Then fix it!
Old 16th December 2009, 05:38 AM   #13733
poynton is offline poynton  United Kingdom
poynton's Avatar
Where have I heard that before ??????
For expert advice on how to break pads. contact Simonty
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 16th December 2009, 09:37 AM   #13734
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Glad you sorted it Steve, it's usually something we do ourselves, as I know only too well.
Yes, I was good at breaking pads but those days are behind me, it's all clean work now Andy
I will post a picture of my current cd63 project in a bit.
Old 18th December 2009, 01:53 PM   #13735
mm2 is offline mm2  Germany
Default CD67 servo amplifiers
Originally Posted by SimontY View Post
I'm modding a CD63 at the moment. ...
I just regulated voltages to two the three servo amplifiers using 7808 / 7908. The results are amazing! The detail, openness, space, smoothness and bass control have really improved a lot! The player sounds very funky.
Simon
Interesting comments Glenn. I feel it's worth pointing out that when compared with like-for-like mods many people prefer the CD67. The CD67 has a regulated 5V for the servo amps / driver op-amps. I'd still recommend people buy a CD63 though, ...
Simon
Hy,
interesting comments.
has anyone tried to increase regulated 5V for the three servo amplifiers in a CD67 ?
According to datasheet TDA7073 up to 18V should be the maximum.
Old 18th December 2009, 02:50 PM   #13736
Malefoda's Avatar
Send a message via MSN to Malefoda
Default She's not bad, she's just drawn that way...
Hi there,
here is my xmas tree!
I had to use only red Leds to get it right...
The CD-43 is finished, it will have to face the CD-40 wich comes next week =)
I'll do sound report of the CD-43 after a decent burn-in, RC LPF and ringing avoided 317 may help a lot.
Another thank you to you all for helping, the result is at least better than the factory player
A grateful Matthieu,
merry melodies to you all!
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, TDA1387, UCD400, JBL 4313B: music!
Old 18th December 2009, 03:05 PM   #13737
Fidelity Audio's Avatar
Nice neat work
Brent
Old 18th December 2009, 03:20 PM   #13738
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Cool... I also like red leds.....
Old 19th December 2009, 11:22 AM   #13739
Malefoda's Avatar
Yep,
and I can check if at least 2 regs are working through the removed headphones' jack
But it does not sounds good. It's held back, lack energy and dynamic. Maybe I need to bypass caps (I did not at all, only big lytics and bypass at pins) or such to improve response? Like very input legs of the regs? That annoying bypass caps story...
Or my output caps combo are not that great, or the BG at DAC's analog and DOS (and pre-amp also!) take years to burn-in... albeit the xmas tree and moved furnitures changed sound and what I am used to... I don't like the way it sounds now
Matthieu
Old 19th December 2009, 12:43 PM   #13740
SimontY's Avatar
Sorry to hear that Matthieu
How much of the problem do you think is the CD player?
Simon
Copyright 1999-2017 diyAudio
