Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 11th December 2009, 10:08 PM   #13711
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Yes, the DOS... thanks guys. The DOS boards are sold out unfortunately
I donated the profit to this forum, ain't I a generous guy! It will get me a nice T-shirt in return though
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 12th December 2009, 05:08 PM   #13712
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
Hi there,
There's Ray written in my player now!
Few times ago we said that analog stage can be left for the end...
It's not the end (many regs to come) but it's sooo good, even if it needs some burn-in (how many hours to your xp guys?).
Matthieu
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Old 12th December 2009, 06:56 PM   #13713
6h5c's Avatar
Cool! Looks very nice, i'm glad you like it. I guess it can take a week or two before it reaches full potential. What kind of regs did you use?
Ray
Old 12th December 2009, 10:22 PM   #13714
Malefoda's Avatar
Hi Ray,
just some 317/337! Simple, cute... and free
Matthieu
Old 13th December 2009, 02:24 AM   #13715
quan is offline quan  Australia
Hi Mat, what caps are those of DOS? Huge+++.
Old 13th December 2009, 05:46 AM   #13716
pooya is offline pooya  Germany
Originally Posted by 6h5c View Post
As for the servo supply, in a CD63 the servo voltages are unregulated, so serious gains can be made here. In a CD67, the supply is regulated with a 7805.
My CD transport use for servo (for TCA0372 ) +/-9V rail from LM317/337 (the simpliest version without diodes).
Most of the standard regulators have fairly good load regulation (only 2...15mV voltage change for full load ON/OFF) and should be able to deal with the PWM driven motor current. The step response is improved drastically by adding a few uF of output capacity, so the 100uF or more in the player should provide plenty buffering.
I can imagine that in some cases the regulator can become unstable with large output caps, I have seen this several times now with the new ONSemi regulators (MC78xxCT series), the ones with the thin metal tab on the housing. An output cap over 100/220uF will make these things oscillate for sure. I have stopped using them and use the ones from ST or NSC now. In the race for smaller and smaller output caps they probably changed the circuit..
So, you are using ST/NSC 78XX regulators for servo...
I never tried a passive supply based on a choke here, but it has the advantage that it is a very effective barrier for noise, and won't go berserk with large output caps. You should make sure that the output impedance is low enough when using a passive circuit (something that can be easily realized by feedback) or the cure may be worse than the problem.
Ray
If I find some free time next week I will simulate few supplies and post the results.
Alex
Old 13th December 2009, 02:06 PM   #13717
Malefoda's Avatar
Hi Quan,
it's a sandwich of a standard MKP 6.8F, a K40Y-9 0.47F russian cap and a FT-1 0.022F Tflon cap. That may not be the best* but it's what I have in hand. If/when I'll built a CD-40 the winner will be tested with these combo and with Obbligato.
And that's not big, I was thinking of fitting K75-10 10F first...
Matthieu
*find the sound a bit mushy in the low mids and a bit digital on femal voices, maybe because it's not burnt-in, the caps combo, no dedicated 5V regs but the factory one, or even the CD-63 sound...
Old 13th December 2009, 03:03 PM   #13718
6h5c's Avatar
Originally Posted by Malefoda View Post
Hi Ray,
Matthieu
Those must be the NSC samples then
Alex
I've used both 7808/7908, 7809/7909 and LM317/337. All work well as far as I can tell. It depends a bit on what I have in stock when a player comes along . I hope the choke version can supply enough current, as the motor's startup peaks are quite high. Looking forward to see your results!
Ray
Old 13th December 2009, 07:25 PM   #13719
studiostevus is offline studiostevus  Netherlands
Tried adding decoder regs... Ended up with a disc motor which spins like mad upon power on. It continues endlessly, and service mode gives 'Error 13, spindle error'. The motor also spins like mad without a disc in it, even with the tray open.
I might have burned C505 with clumsy soldering, but could this be the problem? I've now put back the original resistors R508 and R511 where I had put the regs, but the problems persists.
Any ideas?
Old 14th December 2009, 08:29 AM   #13720
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Bargain clock on Ebay?
Audiocom Superclock 4-s Low Jitter Clock 24.576Mhz on eBay (end time 21-Dec-09 08:30:10 GMT)
Simon
Marantz CD63 & CD67 mods listHide this!Advertise here!
