Marantz CD63 & CD67 mods list - Page 1364 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th December 2009, 03:14 PM   #13631
Glenn2 is offline Glenn2  United Kingdom
Glenn2's Avatar
Is the tip replaceable?
Old 4th December 2009, 03:43 PM   #13632
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Of course, but remember to use lots of flux to get a good flow.
Old 4th December 2009, 03:50 PM   #13633
Glenn2's Avatar
And wipe it on a sponge afterwards.
Old 4th December 2009, 03:56 PM   #13634
SimontY's Avatar
...aaaaand moving back on topic.
What have people's experiences been in removing the last traces of hard/harsh sound sound from the CD63? The question assumes you've achieved that, so most will not be able to answer this.
I find Steve's player still just has a slight bit of grit to the upper midrange and treble. It has 13 extra regulators wired directly to their consumers, upgraded caps in most places, HDAM/muting/caps bypass and HA tin hat op-amps, C1 clock on DAC, a ~80VA transformer supplying DAC/decoder/servo analogue pins, the usual chassis damping.
All that remains are low noise regs, servo re-clock and maybe a better output stage. Thoughts anyone?
Simon
ps - when I used a CD63KI as my main player it didn't have this problem, but I seem to recall the output stage helped to cure it.
Old 4th December 2009, 04:08 PM   #13635
SimontY's Avatar
I know there are a few other little tweeks that could lift things.
Examples: C505 - the HF signal goes through a ceramic cap. That should be a silver mica or at least polystyrene I'd guess.
The 10k resistors in the output filter could be matched or 0.1% items used. I might try that on my current test machine. The polyester filter caps could be changed for polystyrene, polypropylene, teflon or silver mica.
I am going to try output coupling transformers too, and I know changing the naff old sockets lifts some dirt off the sound.
There are always more power supplies to add too.
Old 4th December 2009, 04:09 PM   #13636
SimontY's Avatar
And to help clean things a bit more there's always the coax runs, ground re-routing to a new star and shielding of the uprocessor chip.
Old 4th December 2009, 04:21 PM   #13637
Dropping it from a height of at least 1.2m
Old 4th December 2009, 04:30 PM   #13638
Glenn2's Avatar
I was going to say Simon that your usual trick of letting the smoke out ought to do it.
Old 4th December 2009, 04:41 PM   #13639
SimontY's Avatar
Ahh, cheers guys, yep I know there are better players around but I kinda like messing with these!
Old 4th December 2009, 06:17 PM   #13640
Malefoda's Avatar
Send a message via MSN to Malefoda
Isn't the price/sound ratio very good with the right mods? Go to shop and check what you have for 150€... nothing at all! For that I have a twin clock, regs everywhere, DOS... not that bad for me. And spare parts for cheap.
The fact there is always better is true, if you d'ont mind the price
A happy CD-43 owner.
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, TDA1387, UCD400, JBL 4313B: music!
Copyright 1999-2017 diyAudio
