Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 4th December 2009, 11:43 AM   #13621
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Hi Matthieu,
I'm no engineer but I feel that isn't likely what's happening. I don't know what is causing this behaviour.
Bear in mind Steve's was unhappy with a regulated/lower voltage on the MINUS rail, not the one with the big cap. The -10V rail on Steve's just has the standard 1000uF poo cap.
Simon
Old 4th December 2009, 12:33 PM   #13622
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Hi guys, how are things over here?
Been away for a while for more important matters. Here's the result:
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 4th December 2009, 12:36 PM   #13623
6h5c's Avatar
Her names are Mara Elise , born December 1st, 13:34.
I'm a happy man!!
Old 4th December 2009, 12:51 PM   #13624
SimontY's Avatar
Oh, congratulations Ray, she's very cute!
Any mods planned or will you keep her standard for the next 15-20 years?
Simon
Old 4th December 2009, 01:09 PM   #13625
Glenn2 is offline Glenn2  United Kingdom
Glenn2's Avatar
Congratulations Ray!
LOL @ Simon
Servo amps - I used LM317/337 at 7.5V and never had my player skip a beat, infact it tracked better after (quicker to lock onto track) but I may have imagined it. Bear in mind you have to do a bit of re-routing of the power lines for one of them. You have to isolate a track from one of the big caps to one of the amps and connect it the other side, then you can remove a jumper for your new reg input/output. It should be clear looking at the service manual layout.
The amps only output 5V signals and if you use 7-7.5V regs that's enough overhead for amp and regulator, i.e., 10V-->7V-->5V.
Old 4th December 2009, 01:12 PM   #13626
6h5c's Avatar
Thanks guys. I think i'll keep her standard first, see how she sounds first, and maybe, if I don't like her tone after a few years...
May have to go shopping for a pink soldering iron, who knows...
Ray
Old 4th December 2009, 01:15 PM   #13627
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
That's your greatest success Ray! =) So cute!
We are at least 2 to have noticed a faster reading
And I did re-routed one of the PS, one jumper removed (positive one) and a wire after reg to after jumper pin.
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Old 4th December 2009, 01:23 PM   #13628
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
Congratulations Ray
December will not be cheap from now on
P.S Simon already has a pink iron
Brent
Old 4th December 2009, 01:26 PM   #13629
Glenn2's Avatar
Bottle-fed I hope? (as a valve/tube man...)
Regards to the track re-routing;
1) Remove U234, U161 and U237 shown in red to isolate the drivers from the raw supplies.
2) Insert -ve reg at U234 (use holes as input and output)
3) Insert +ve reg at either U161 or U237 (use holes as input and output
4) Connect blue wire as shown (you can use any colour )
Simples.
Old 4th December 2009, 01:41 PM   #13630
SimontY's Avatar
How innocent the man is, that's no soldering iron, but it is rated 100w...
Marantz CD63 & CD67 mods listHide this!Advertise here!
