| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#13591 |
Steve, They definately shouldn't need setting up but in my experience they often do!!! It does seem hit and miss with them. You could return the unit and try another. I had a really bad one once that I swapped just the laser head into the old mech. That worked pretty well.
As for the adjustment, there is a small trimmer on the flexi pcb on the underside of the laser. If there is also 2 hex screws that physically move the laser mech in relation to the disc. A tweak on one of those hex screws may be better of the motors been squashed????? My overall advise would be have a play. You could always return it after if you make a right mess of it! Ian
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk JA-88D Class A, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard" |
#13592 |
I forgot to mention this the other day when I saw it.
|Ebay modded cd63 Intersting mods here. I wonder if fitting the bracing bar the wrong way round helps with the sound at all??? Also, i never considered fitting a 67 mainboard to a 63 as an upgrade before!!!!! ![]() ![]() It did make me chuckle tho'!!!
#13593 |
If sou you should be able, by gently push up on both sides at once using something large and flat, to lift it up at about the gap you can see on the KI's one.
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music! |
#13594 | |
Yes damping material and opamps is a major upgrade ![]() Brent |
#13595 | |
It doesn't really matter, but if it bothers you, you can get small, flat magnets the size of pennies and lay one of those on the top of the clamp. Works a treat. |
#13596 |
Oh gosh, internal carpet, there's your £850 worth right there.
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#13597 |
Probably a nice static inducing nylon weave too
![]() Brent |
#13598 |
Magneto the Gravity Man
Has got a bypass on the HDAM......wonder where they got that idea?
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#13599 |
I wonder
![]() You could've picked a better time of year to be in the UK Andy! ![]() Simon
#13600 | |
Off to Papua New Guinea for 5 weeks mid-December. Andy .
