Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th November 2009, 12:36 PM   #13531
grofus is offline grofus  United Kingdom
Default No Display
Originally Posted by 6h5c View Post
Hi Steve,
You can check if the negative display voltage is present at Q851. It should have about -24V at the output.
Ray
Ray,
Measured voltage at Q851 was -0.61v. I'm guessing a broken track or dry joint around the diodes. I measured voltage across the diodes and got no reading on a couple.
Steve
Old 17th November 2009, 11:45 PM   #13532
Default Steve
Can anyone help please! Just replaced a pair of op amps and wired in a shielded power cable and put everything back together. Now my player spins a disc but does not recognise a disc.
Help please,
Steve
Old 18th November 2009, 12:36 AM   #13533
Malefoda's Avatar
Send a message via MSN to Malefoda
I say gently replace well the small ribbon cable from mech to main PCB. Hope for you it's only that
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music!
Old 18th November 2009, 07:18 AM   #13534
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
Originally Posted by grofus View Post
Ray,
Steve
Hi Steve,
Hope it's a small problem. You should sort out the negative input voltage to Q851 first. The problem with these boards is, they sit in the player untouched for years, and after tweaking the trouble starts...
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 18th November 2009, 12:35 PM   #13535
Hi Steve,
Ray
Right, got -17.5v at Q851. Broken tracks. But still no display. To be honest, although i'm learning fast, I think it's beyond me. Seemed to have hit a brick wall. For some reason, no voltage across D814, and both DN03/04. Any ideas! cheers, Steve
Old 19th November 2009, 12:17 AM   #13536
Default Steve
Hi all,
just got error 10 in service mode (radial), not sure what this means. Can anyone offer any ideas? Could it be related to swapping opamps.
thanks
Steve
Old 19th November 2009, 05:40 AM   #13537
flyboi is offline flyboi  Malaysia
Send a message via ICQ to flyboi
Hi guys!
I've done the bessel filter mod as per the modded list. I've come across the Mauro Penasa's filter tweak. If I add the Mauro's tweak, will it upset the bessel filter frequency curve? Or is it another must do list?
Eddy.
Old 19th November 2009, 09:00 AM   #13538
Fidelity Audio's Avatar
Originally Posted by stevief198 View Post
Hi all,
thanks
Steve
Error 10 is a radial error. Nothing to do with output. The output should never have any baring on the service mode codes as it is an independant circuit from the servo, decoder, dac & cpu data loop.
Brent
Old 19th November 2009, 11:29 AM   #13539
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Hi all,
thanks
Steve
You'll probably have disturbed one of the two ribbon cables or a 5V rail. Measure for +5V at each chip (servo, decoder, DAC) and lightly fettle the ribbon from the transport to the main pcb whilst the player's on and see if you can get a response. To check the front ribbon - unplug it and turn the player on - it should read and play the disc, only with no display or controls.
Simon
Old 19th November 2009, 12:20 PM   #13540
RCruz is offline RCruz  Portugal
RCruz's Avatar
The ribbon from the mech to the main pcb is very fragile and once gave me error 10 also.
Page generated in 0.21073 seconds (57.61% PHP - 42.39% MySQL) with 11 queries
