Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th November 2009, 05:48 PM   #13521
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
Originally Posted by studiostevus View Post
Ray, I connected everything. I now have one of the original 100ohm resistors between the the hdam-bypass and the RCA's. Volume is pretty low now, for my understanding, what are the other side-effects from having this 100ohm instead of your recommended 47ohm?
(didn't have a 47ohm here, just a 40 or 100)
There shouldn't be any side-effects. 40 ohm, 47ohm, 100ohm, that really shouldn't matter much in sound level. Volume should be just as loud as with the HDAM in place. In the original player, there's 2x 100ohm in series, so theoretically it should be louder now
Are you sure you have everything connected properly? Opamp output > 100 ohm > output socket
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 15th November 2009, 05:50 PM   #13522
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Originally Posted by Malefoda View Post
How do you know if it's balanced or not? I think it is as it looks symetrical...
Ricardo why not a new thread! That may be exciting =)
It has balanced outputs
How can I start a new thread ?
Old 15th November 2009, 05:54 PM   #13523
grofus is offline grofus  United Kingdom
Hi all, I'm Steve. Yes, another one. I need some advice. I have upgraded the diodes to schottky and in doing so the display has ceased to function. I read somewhere on here another member had the same problem. I just need to know where to start looking as i'm a novice. The player works fine with great sound apart from the display. Any ideas welcome. Great forum by the way. Thanks, Steve
Old 15th November 2009, 05:56 PM   #13524
Malefoda's Avatar
Send a message via MSN to Malefoda
Just clic Digital Source - diyAudio then "new thread". It's always nice to see good players back to life
Ok let's check Studiostevus work, sorry for ot Ray!
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music!
Old 15th November 2009, 06:27 PM   #13525
Double checked it... I measured with DMM 100ohm between the start of the bypass and the RCA's, so should be fine. Maybe it's the new opamps that are a bit quieter.
So.. where do we stand:
- muting circuit removed
- muting caps gone
- Raygulators for the +/- 12V rails
- LM4562 opamps
- Bypassed HDAM
What's the best thing to follow?
Clock?
Or are there some more caps to remove/change (In a SE version) ?
Old 15th November 2009, 06:32 PM   #13526
Glenn2 is offline Glenn2  United Kingdom
Glenn2's Avatar
Lee,
I would be very happy if you can tell me how you spiced your TDA1547
Right now I plan on using an extrenal single opamps like top Analog Device or National Semi to do the work of the internal ones and the DOS it.
Again, I'm begging all you even if have different points of view (that makes us more rich!) on my Philips CD951 • A DAC7 (TDA1547) vs TDA1541A R1 vs SM5872 story ! Promise I won't do (too soon...) commercial break for my church again
I was talking about PCM56 in the Denon.
And I wasn't talking about external op-amps, I was talking about the I/V opamps INSIDE the PCM56. You can take I-out before these or V-out after these as the both signals have output pins.
Old 15th November 2009, 06:40 PM   #13527
RCruz's Avatar
Clock?
Just follow Ray´s list....
Next thing I would do is replace the stock 7805 main +5v reg by a LM340AT... That should give an overall boost right now.
Old 15th November 2009, 07:24 PM   #13528
6h5c's Avatar
Hi Steve,
You can check if the negative display voltage is present at Q851. It should have about -24V at the output.
Ray
Old 15th November 2009, 07:48 PM   #13529
Default Steve
Ian,
thanks again.
what rating for the caps 16V or 35V?
really grateful for the help,
Steve
Old 15th November 2009, 08:03 PM   #13530
Originally Posted by 6h5c View Post
Hi Steve,
Ray
Thanks Ray, I will check that tomorrow
Copyright ©1999-2013 diyAudio
