Marantz CD63 & CD67 mods list - Page 1352 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th November 2009, 11:38 AM   #13511
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
If you reed a bit further in the datasheet (AD8510), some values for the snubber network are given. It depends on the capacitance of the interlink and input capacity of the next stage. But 500pF is a lot, I don't think any interlink has that much capacity. My Nordost has only 8.9pF/feet (which is quite low). A series resistor also reduces ringing, I never tried a snubber, maybe that works even better. I'd say try it, and see how it sounds
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 15th November 2009, 11:47 AM   #13512
Ray, you mean resistor between output of the opamp and RCA or between ground and RCA?
Was about to replace the standard opamps in my cd63se today for a lm4562. Thought it was a matter of plugging it in and bypassing HDAM. Now it seems a bit more to it...
Old 15th November 2009, 02:02 PM   #13513
6h5c's Avatar
I mean between the opamp and the output sockets, about 47 ohm is often used. Although it is not a bad idea to insert a resistor between the output and ground too, to prevent an open output in case the player is not connected to anything. These are already present in the player, R655 and R656, 10k. I usually raise them to 100k.
Ray
Old 15th November 2009, 03:34 PM   #13514
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Ray
I need to place a dos in a DENON DCD3300....
It is an old player built like a tank and surelly worth the work.
My first issue is related with some errors I am getting while trying to read discs... it does not read them all and most of the times, when reading, it produces a scratching noise (directly related with the CD spin speed).
Can you please tell me if I should replace the lens and if after that I could install the dos ?
Ricardo
PS: Sorry for the off topic
Old 15th November 2009, 03:57 PM   #13515
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
DENON DCD3300, PCM56 dac Ricardo. Very nice indeed!
I expect you'll need more gain from the dos, unless it has higher output than the TDA1541. You may also be better with a transistor version as opposed to fet as they're reputed to be better for current/voltage conversion, although I didn't try this.
Lee.
Lee.
Old 15th November 2009, 04:29 PM   #13516
Glenn2 is offline Glenn2  United Kingdom
Glenn2's Avatar
Yes a DOS is probably not what you need. It's for balanced voltage output DACs.
This DAC has unbalanced current output and an internal I/V op-amp for unbalanced voltage output too.
The player may of course have two per channel for differential signals, I don't know.
If you use the internal I/V op-amps for v-out, and there are two per channel giving balanced voltage, you can use the DOS. (You could use it for unbalanced too but there wouldn't be much point.)
Maximum performance would be to use the current outputs and a discrete I/V stage.
But remember the DOS does not perform I/V conversion.
Old 15th November 2009, 04:45 PM   #13517
nhinstruments
RCruz's Avatar
How can I determine if it has two opamps per channel ? (I can see 3 x NE5532P on each channel and it has balanced outputs)
Old 15th November 2009, 04:57 PM   #13518
Ray, I connected everything. I now have one of the original 100ohm resistors between the the hdam-bypass and the RCA's. Volume is pretty low now, for my understanding, what are the other side-effects from having this 100ohm instead of your recommended 47ohm?
(didn't have a 47ohm here, just a 40 or 100)
Old 15th November 2009, 05:21 PM   #13519
nhinstruments
RCruz's Avatar
Hi lee
I agree that it looks quite cool but I am having trouble with the lazer... can you help me find a replacement ?
Old 15th November 2009, 05:37 PM   #13520
Malefoda's Avatar
Send a message via MSN to Malefoda
Lee,
I would be very happy if you can tell me how you spiced your TDA1547
How do you know if it's balanced or not? I think it is as it looks symetrical...
Right now I plan on using an extrenal single opamps like top Analog Device or National Semi to do the work of the internal ones and the DOS it.
Again, I'm begging all you even if have different points of view (that makes us more rich!) on my Philips CD951 A DAC7 (TDA1547) vs TDA1541A R1 vs SM5872 story ! Promise I won't do (too soon...) commercial break for my church again
Ricardo why not a new thread! That may be exciting =)
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, TDA1387, UCD400, JBL 4313B: music!
Copyright 1999-2017 diyAudio
